Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2009 F150
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-08-2008, 12:47 PM
ArtsBest is starting off with a positive reputation.
6f35 6-speed Transmissions?
Is this the transmission in the new 09' F-150?
Ford Motor Co. said Wednesday it plans to double the number of six-speed automatic transmissions in its models by the end of next year, increasing fuel efficiency to the point where it's equal to or better than manual gearboxes.
The company also said that 98 percent of its North American transmissions will be six speeds by the end of 2012 as it moves to meet increasing government fuel economy standards.
The computer-controlled transmissions, built at a revamped factory in Sterling Heights, give drivers a 4 percent to 6 percent gas mileage boost compared with the four- and five-speed models now in widespread use in Ford's front-wheel-drive vehicles.
Because the computer calculates when to shift gears so the engine runs at peak efficiency, they can rival the mileage of lighter manual gearboxes, said Ram Krisnaswami, a Ford powertrain engineering manager.
The new transmissions allow the car to achieve higher speeds with fewer engine revolutions per minute, making it more efficient, Ford said.
The Dearborn-based automaker says its 6F35 six-speed transmissions will debut in the 2009-model Ford Escape and Mercury Mariner crossover vehicles, which now have four-speed automatic transmissions.
The new transmissions will also be low-maintenance, with no need to replace the fluid in the gearboxes for the life of the vehicle, Ford said.
"They also deliver improved acceleration and smoother shifting, all at a great value for consumers," she said in a statement.
Ford said it plans to sell 1.4 million six-speed vehicles in North America by the end of next year. In addition to the 6F35 transmissions, Ford also makes another six-speed transmission that was jointly developed with General Motors Corp.
Ford said it invested $658 million in Sterling Heights and at factories in Livonia and Sharonville, Ohio, to make the transmissions.
Krisnaswami said six speeds are very efficient and cost effective, and automakers have to weigh efficiency gains against added costs, weight and shifting that come with more gears.
  #2 (permalink)
Old 05-08-2008, 12:57 PM
bpounds's Avatar
bpounds is gaining momentum as a positive member of FTE.
Probably not. Too small. The "35" has to do with the torque rating, and that's too small for an F150. They will have a higher rated unit for the truck and Exp, and another even larger for the Superduty. All just speculation by me.
What I'm wondering is how they will arrange the 6 speeds. If it's just a double overdrive, it's not much good except for high speed cruising with light loads. But I'm guessing that's what it will be.
Bill
__________________
*Bill*
2006 F250 XLT SCLB FX4 4x4 6.0L Automatic, Magnaflow Turbo Back, Rhino Liner, Retrax Bed Cover, Cab Lights Retro-fit, Overhead Console Retro-fit, Harpoon Mod, C-Betrs. Pulling Fleetwood Pioneer, 23', 5,200#
  #3 (permalink)
Old 05-08-2008, 02:52 PM
Big Bad is gaining momentum as a positive member of FTE.Big Bad is gaining momentum as a positive member of FTE.
6F is a FWD transaxle.
09 F150 will get the 6R80 I believe.
  #4 (permalink)
Old 05-08-2008, 03:11 PM
Quote:
Bill
The 6R trannies have some of the best gear spacing in the business They don't even have a 1:1 gear to keep the gears more enly spaced.
1st 4.17:1
2nd 2.34:1
3rd 1.52:1
4th 1.14:1
5th 0.87:1
6th 0.69:1
Reverse 3.40:1
  #5 (permalink)
Old 05-08-2008, 03:37 PM
bpounds's Avatar
Quote:
Yep, if that info is correct, it's a double overdrive. I really don't need a lower RPM at 75mph.
Bill
__________________
*Bill*
  #6 (permalink)
Old 05-08-2008, 04:12 PM
Lead Head is starting off with a positive reputation.
Bill
It will use less gas. This will also allow ford to use bigger geared rearends, like 3.73:1 or 4.10:1 to let cars still have good mileage, but plenty of acceleration and such.
Anyone else also think its kinda crappy that once again ford is not letting you change the fluid in the transmission easily? I don't see how they expect ATF to last 200-250k.
__________________
- Ian
1987 Ford Ranger XLT 4x4 2.9
Needs a lot of work, including some rot on the body, but shes getting there.
  #7 (permalink)
Old 05-08-2008, 04:28 PM
bluedevil3758 is starting off with a positive reputation.
.69 as opposed to the .7 final ratio found in f150s now? i dont think that will make to much difference and why wouldnt you want lower rpms on the highway?
__________________
1999 ranger 3.0l 4x4 4.10
2005 f150 2wd 5.4 scab 3.73s
  #8 (permalink)
Old 05-08-2008, 05:08 PM
Bill
That info is correct, and you will be hard pressed to find a trans with a 0.87:1 overdrive anywhere.
The current 4R75 gear ratios.
1st 2.84:1
2nd 1.55:1
3rd 1.00:1
4th 0.70:1
Reverse 2.23:1
In other words, no comparison whatsoever, not in any way, shape or form.
  #9 (permalink)
Old 05-08-2008, 06:31 PM
bpounds's Avatar
Okay, .88 vs 1.00. I don't call that a big deal. But what I do find remarkable is that low 1st gear. I could have really used that on my previous truck to get a load started on a grade. Now that I look at those numbers again, with that low gear in mind, that does sound really good.
Do you know which vehicle will use those ratios? Is that just for the F150 class? Or do you expect that strategy to be used in the Superduty series?
Bill
__________________
*Bill*
  #10 (permalink)
Old 05-08-2008, 08:26 PM
wiingnut is gaining momentum as a positive member of FTE.
6r80 is correct for the rear wheel drive trans.
__________________
08 F350 SRW KR CC LB 4X4 Dark Copper Metallic V-10/Torque Shift, Loaded UP!!
49 Ford 8N
05 Focus ST
07 Edge SEL (Wifes)
This isn't your father in law's Buick. Step back
and no one gets hurt!
  #11 (permalink)
Old 05-08-2008, 09:17 PM
montecarlo31 is starting off with a positive reputation.
I have the 6 speed in my expedition (08) and it's a great trans, the key that ford is missing the boat on compaired to GM's 6 speed is the ability to shift each gear on the stalk and having a tow haul mode. Another interesting point is that the trans is only rated at 15K lbs GCVW. I've towed well over 10K lbs w/ my expy and haven't had any temp related problems. That weight rating won't help for set the towing standard that they are claiming to have on the new units.
  #12 (permalink)
Old 05-08-2008, 09:37 PM
i think they up graded it a little, but im not so sure top towing and payloads have increased, i think most of the increases will be in the screw style
All internal components of the smooth-shifting 6-speed have been upgraded to handle higher torque capacities; these include more robust clutch packs, bigger pump and bigger output shaft. The transmission’s hydraulic system also was beefed up to enable improved idle speeds and improved converter clutch duty cycles.
__________________
  #13 (permalink)
Old 05-09-2008, 11:13 AM
Blue Bomber is starting off with a positive reputation.
is this by any chance related to the 6 speed auto in the mustang.
if so, i wonder how many people would start swapping transmissions.
__________________
my truck is for sale. you wanna buy it???
http://www.ford-trucks.com/classifie...t/21978/cat/17
  #14 (permalink)
Old 05-09-2008, 11:36 AM
carbonmetallic is starting off with a positive reputation.
I 've got news for you, my computer controlled 6 speed transmission on my 07 Ford Expedition sucks ass. Half the time the computer doesnt know what gear to pick and jolts you around. Mr. Ram Krisnaswami, a Ford powertrain engineering manager ought to come down to Texas and drive this crappy 6 speed transmission before he makes the kind of statements he is making. Sure if everything performed correctly it would work, I am just hoping the new F150 doesnt get the expeditions 6 speed transmission or the next vehicle i purchase may just have to be something other than ford.
  #15 (permalink)
Old 05-09-2008, 12:11 PM
sorry, i ment 5 speed auto.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.1.0 ©2007, Crawlability, Inc.
Ford-Trucks.com and Ford Truck Enthusiasts, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Ford Truck Enthusiasts, Inc., Please see our legal notices and privacy statement.
