Quote:
Originally Posted by The Oldtimer
AOD 1st gear...2.84
6R 2nd...2.34
That ain't virtually the same...!!! They should have made 2nd in the 6R in the 2.80s.
AOD/AODE 1st gear: 2.40:1
...virtually the same as the 6Rs 2nd.
Here's a quick comparison on trans gearing I made in another thread.
Keep in mind this calculator is assuming a locked torque coverter, which usually isn't the case on a 1-2 upshift. The unlocked torque coverter, assuming it is stalled correctly, should allow the converter to flash a bit higher than the rpm values shown.
The Ford 6R80 (4.17, 2.34, 1.52, 1.14, 0.86, 0.69) with a 5500 rpm upshift, 3.73 gear and a 30" tire diameter puts the:
1-2 @ 33 mph and 3200 rpm in 2nd
2-3 @ 57 mph and 3600 rpm in 3rd
3-4 @ 88 mph and 4200 rpm in 4th
4-5 @ 117 mph and 4200 rpm in 5th
5-6 @ 153 mph and 4400 rpm in 6th
Compare to the current Ford 4R75 (2.84, 1.55, 1.00, 0.7) still shifting at 5500 rpm even though they actually shift at 5,000 rpm:
1-2 @ 46 mph and 3000 rpm in 2nd
2-3 @ 86 mph and 3600 rpm in 3rd
3-4 @ 133 mph and 3900 rpm in 4th
The Toyota Tundra 6-speed (3.33, 1.96, 1.35, 1.00, 0.73, 0.59) with the same axle ratio, shift point and tire diameter:
1-2 @ 41 mph and 3400 rpm in 2nd
2-3 @ 67 mph and 3800 rpm in 3rd
3-4 @ 97 mph and 4100 rpm in 4th
4-5 @ 132 mph and 4050 rpm in 5th
5-6 @ 180 mph and 4500 rpm in 6th
The GM 4L80 (3.06, 1.63, 1.00, 0.70) with the same values:
1-2 @ 43 mph and 3000 rpm in 2nd
2-3 @ 81 mph and 3400 rpm in 3rd
3-4 @ 132 mph and 3900 rpm in 4th
Yea, I'm pretty happy with the 6R80. It's 1-2 could be spaced a bit better I suppose, but it's a best in class transmission with best in class gear spacing. I'm happy with best in class.
