Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Aerostar
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-08-2008, 08:38 AM
crxess is starting off with a positive reputation.
Power Steering - riddle me this......
How does a sealed system get moisture inside?
After researching here a year ago, I flushed and refilled the Power steering system on my '94 Aero. It took a few days driving, but the system totally frees up and started working great again. Saved big bucks too!
Now, it just failed again. Ps works fine @ ddriving speeds. Slow and stopped = no assist. Fluid is once again HOT PINK and MILKY looking.
No signs of fluid loss.
Any feed back?
Thanks
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-08-2008, 09:53 AM
cookkd is starting off with a positive reputation.
Any feed back?
Thanks
Take a look at that rubber, funnel looking thing that is right over the fluid reservoir. Most people that have been driving a 'Star for any length of time will take a beer/soda can, cut it in half and place it over the reservoir. Water leaks from the rubber thingy right on top of the cap.........
__________________
'90 Eddie Bauer Ext, 3.0 - 254K (Parts Car)
'91 XLT Ext, 3.0 - 124,000 (slowly becoming an EB)
'86 Caddy Fleetwood FWD - 115K
'00 Merc Grand Marquis LS - 21K
'99 Merc Mountaineer - 112K
'92 Merc Cougar LS, 25th Anniv Edition - 98K
  #3 (permalink)
Old 05-08-2008, 10:39 AM
copper_90680's Avatar
copper_90680 is a splendid one to beholdcopper_90680 is a splendid one to beholdcopper_90680 is a splendid one to beholdcopper_90680 is a splendid one to beholdcopper_90680 is a splendid one to beholdcopper_90680 is a splendid one to beholdcopper_90680 is a splendid one to behold
Hi Crxess,
Welcome to our forum
There has been a lot of discussion about moisture in the P/S system. The consensus is that the moisture gets in because the gutter drain (that flat rubber tube on the firewall near the top of the P/S cap) is too close to the cap and some of the water got into the P/S through the vent on the cap. I think it's either Ken or Cliff who came up with the idea of a sawed-off beer can (or soda can) over the cap to prevent this from happening. You might try it since it can't do any harm. A beer is always a good idea when you're not driving.
__________________
Tung
'93 3.0L Aerostar 2WD
'95 4.0L Aerostar AWD
'93 3.8L Taurus
Please check out our guideline
http://www.ford-trucks.com/guidelines.html
Wife? What wife? Oh, The Supreme Commander!
  #4 (permalink)
Old 05-08-2008, 12:36 PM
96_4wdr's Avatar
96_4wdr is gaining momentum as a positive member of FTE.
must have been Ken
my beer cans are too large
also the heat/cool cycles draw air thus moisture into the ps system.
put in an inline filter. use search function
Microfine or other brand, auto parts stores
my cowl drain was filled with fir needles at the drain hole into the rubber tubey last winter totally plugging it up. caused it to leak thru seam directly onto top of engine. thought i had another coolant leak until i checked it on a rainy day.
  #5 (permalink)
Old 05-10-2008, 08:10 PM
93nighthawk's Avatar
93nighthawk is starting off with a positive reputation.
Welcome!
I concur with what has been said, use a pop can and cover that puppy!
__________________
'96 Ford Contour 2.0 I4 MTX 77k mi- Rear Ended 12/22/07
'97 Ford Aerostar AWD 4.0L v6 AT 81kmi
'97 Chevy Lumina 3.1 v6 ATX 135k mi Parents old beater, temp vehicle
Future: 2009/10 Taurus SHO, Loaded
My Car Domain
The Possum Aero-Van!
  #6 (permalink)
Old 05-10-2008, 08:46 PM
JTHill24 is starting off with a positive reputation.
Bad seal in your Rack n Pinon. My son's ol Olds Ceria does the same thing. Flush it out, Refill with fresh fluid. Lasts any where from 1mt to 3mts. Open the pump lid and it looks like mud. Also the powering steering quits working then works when it wants too.
It's leaking some kind of Grease/oil into & mixing in the steering system.
JaY
__________________
Removing from the Front a Aerostar 3.0/4.0 Engine & Rebuilding a 3.0 WebPage
(New Home)
http://www.webng.com/JTHill/
  #7 (permalink)
Old 05-11-2008, 01:44 AM
Pablo-UA is starting off with a positive reputation.
I rebuilt my r'n'p. No magor leaks, but seals pinion seal is dirty around. and i see atf drops on my driveway. I used to add a bit, but a quater of atf is still not used for a year.
  #8 (permalink)
Old 05-13-2008, 08:38 PM
Aeroman59's Avatar
Aeroman59 is starting off with a positive reputation.
Thumbs up Breather hole downwards.
Power steering system is under pressure when you steer, should be no leaks for water to enter or oil would escape.
The filler cap/ dipstick has a breather hole in it, make sure this hole faces to the low side of the pump ....ie the hole is towards the road. Because the pump resevoir is angled the water which gets into the cap will drain away before it gets as high as the breather hole. if you fit it the other way it is possible for a pool of water to cover the breather hole. When fluid expands & contracts a vacuum is created which could suck this water into the reservior.
The beer can would work too but I do what I just said & no water for 9 years,
Touch wood !!
'Aeroman
__________________
Green-96, XLT 2wd, 3L Vulcan, from Ontario, Canada
All original powertrain except alternator & starter motor. 292,000 kms & going strong !
  #9 (permalink)
Old 05-14-2008, 01:17 AM
Sponsor
Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.
Wether or not you do get water depends on if the gutter is plugged and also if the seal along the back of the hood is intact. That is where water gets in, I have seen it happen.
__________________
My Rides
1994 Ford Aerostar 4.0L AWD extended
175,000 miles
Fullblown 50 series catback system
590 watt sound system
AFE ProDryS filter
1990 Mazda B2600i
505,000 miles
Custom exhaust with BearCats high flow converter and a straight through muffler
Custom high velocity intake with AFE ProDryS filter
http://www.bearriverconverters.com
  #10 (permalink)
Old 05-26-2008, 08:14 AM
Luck ran out this time. Rained here for 7 day straight. Forced me to drive it to work as-is for 3 days.
The pump started making a deep growl and picked up a heavy vibration in the steering wheel.
Flushed it out yesterday until everything ran clean. Pump still growling and vibrating. Thrust area must be toast.
Picked up a reman. and tools to swap the pulley. Will be changing today.
I will definately cover the fill cap from here out.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
