Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Modular V8 (4.6L, 5.4L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-08-2008, 01:26 AM
Jason01 is starting off with a positive reputation.
Cool COP/misfire problem!
Ok... I have had plenty of issues with this truck, and if it doesn't get better soon, its going to find the fast way off a bridge... lol
On to my question....
I recently changed the timing chains, and pretty much immediately afterwards the truck started idling like crap. Engine light was on, took it in to see what new codes I had, and it says that Coils 3 and 5 are not working right. Now, I do believe in bad luck, and I suppose this thing could kill 2 1 year old coils at once, but I'm not so sure. Before I shell out the bucks for these, are there anythings that I should check first? the looked like they were plugged in just fine(I had to unplug most of the coils to get the chains on). I am mostly wondering what the resistance should be on the coils, and which cylinders are which....
One other thing... this thing had a MASSIVE oil leak, and before we began on the chains, we washed the engine. Didn't use a power washer, only a garden hose and a few cans of degreaser. Is it possible that water has gotten in there and would still be there 2 weeks later?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-08-2008, 01:50 AM
Zip's Avatar
Zip Zip is online now
Zip has a great reputation on FTE.Zip has a great reputation on FTE.Zip has a great reputation on FTE.Zip has a great reputation on FTE.
I guess you could take those two coils and move them to different cylinders. If the missfire changes cylinders you have a pretty good idea its the coils. I just had one of mine go and moved it just to confirm. Other than that I can't offer much more assistance. Someone with a little more knowledge should show up shortly.
__________________
Chris
JOIN THE BRITISH COLUMBIA CHAPTER CLICK HERE
03 F350 Crew Cab 4x4 S/B
No mods
WHAT NO MODS
Gotta change that.
My wife said "No you can't use the dishwasher to clean hubcaps!"
I said hmmm....parts washer....my mom always said engage brain before operating mouth...now I know why
  #3 (permalink)
Old 05-08-2008, 09:29 AM
projectSHO89 is gaining momentum as a positive member of FTE.projectSHO89 is gaining momentum as a positive member of FTE.
You probably got water down in the plugwells and are shorting out the spark.
Pull the suspect COPs and dry out the well. If you're lucky, the COPs didn't get damaged (don't hold your breath).
Steve
__________________
Think about it: Ignorance can be addressed through education but you can't fix stupid! ...apologies to Ron White
  #4 (permalink)
Old 05-08-2008, 09:30 AM
Manipulator is starting off with a positive reputation.
Water can get in past the boots and into the spark plug passage. The previous owner of my Expedition must have washed the engine at one time. When I changed the plugs a few were rusty like water had been in there. Pull all the coils and blow compressed air in the there. Could be you have some water in there causing some misfires.
  #5 (permalink)
Old 05-08-2008, 11:35 AM
the water would still be causing a problem 2 -3 weeks later? wow.... I will try to get the #5 pulled out today. If I understand right, cylinder 5 is the front drivers side, right?
  #6 (permalink)
Old 05-08-2008, 11:39 AM
Zip's Avatar
That would be the correct location of cyl #5.
__________________
Chris
No mods
WHAT NO MODS
Gotta change that.
  #7 (permalink)
Old 05-10-2008, 07:21 AM
Quote:
It is very difficult for the water to get out of there once it gets in. Yeah, weeks, months, maybe never on its own.
If it was forced in under pressure, the boot still seals well enough so it can't evaporate (no vent).
Steve
__________________
  #8 (permalink)
Old 05-10-2008, 11:21 AM
galaxie641 is starting off with a positive reputation.
AS one of the first replies said always move the COP's to different cylinders and see if the misfire follows. Obviously if it does the COP is bad, if it doesn't you have a plug or injector problem, or even a bad harness at that cylinder.
__________________
'48 F1 Flat6
'51 F3 Flat8
'64 Galaxie 352 4bbl
'68 F150 390
'72 F250 400/C6
'97 F150 5.4L
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
