Go Back   Ford Truck Enthusiasts Forums > Misc. > Clutch,Transmission, Differential, Axle and Transfer Case
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-07-2008, 11:12 PM
m000996 is starting off with a positive reputation.
C6 Tail Piece.. 2WD vs. 4WD
I'm swapping C6 transmissions in my '75 F250 4x4. I have found a cheap, usable C6 tranny, but it is out of a '79 F250 2WD. Obviously, the tail pieces are different on the 2WD vs. 4WD transmissions. Can I replace the long tail piece on the '79 2WD C6 with the shorter tail piece from my '75 4WD? I want to keep the tail piece because it is the mounting point for my transfer case linkage back to my divorced NP203. Thanks for the help, Mike
__________________
Mike in Southwestern PA
1975 F250 4x4
- Stock 360FE, C6 Automatic, NP203 w/ WARN Part-Time Conversion, 4.10 D44HD/D60 Gears
2003 Expedition Eddie Bauer
- 5.4L Triton, 4WD
1965 Mustang Fastback
-Ragoon Red, A Code 289, Money Pit, Work in Progress
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-08-2008, 08:06 AM
385seriesHemi is gaining momentum as a positive member of FTE.
I would believe you could BUT you will be having to change the output shaft also.
__________________
Jim "Iron Giant" Fahlin ~ A high performance car is like a guitar, you have to tune it to achieve your best operation and pull ahead of the competition.
  #3 (permalink)
Old 05-08-2008, 11:37 PM
mark a.'s Avatar
mark a. is gaining momentum as a positive member of FTE.mark a. is gaining momentum as a positive member of FTE.
You have to tear the trans completely down, there is no way out. The tail shaft has to be changed over & it has to come completely apart to do that, so you might as well rebuild what you have.
__________________
'79 F250 13" lift 42" Super Swampers
  #4 (permalink)
Old 05-09-2008, 08:43 AM
Thanks for the responses.. I plan on tearing down the 2WD transmission anyway to rebuild it. The driving force behind this effort is a motor swap from a 360FE (big block C6 bellhousing) to a 300-6 (small block C6 bellhousing). The 2WD C6 is part of a 300-6/C6 combo that I'm getting from a '79 F250 2WD.
__________________
1975 F250 4x4
- 5.4L Triton, 4WD
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
