Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #31 (permalink)
Old 05-08-2008, 10:28 PM
ramarado is starting off with a positive reputation.
I don't see how they really went anywhere. If the dist freezes so does the oil flow. The pump drives off the dist.
  #32 (permalink)
Old 05-09-2008, 07:32 AM
Lance Hogan is starting off with a positive reputation.
My neighbor was busy last evening and did not get a chance to look at my cam gear for a second opinion. I have turned the motor over (using a ratchet) to reevaluate the cam gear and to me, it looks to be ok. Further, I want to make clear that a few metal pieces were on top of the first lifter (driver side) where the push rod sits. The pieces might have landed in that location when I pulled the distributor out???
  #33 (permalink)
Old 05-09-2008, 08:44 AM
Redmanbob's Avatar
Humble servant of my Peni
Redmanbob is gaining momentum as a positive member of FTE.
If nothing else I think I'd pull the cam and lifters and wipe them down. Maybe disassemble the first few and check for debris ? Wouldn't think the rotating assembly has seen much unless you flipped the motor. You could pull it all down to be sure, not mandatory, but think you might be playing with fire. I wouldn't be able to sleep for a while LOL
__________________
66 F100 352 V8
"Po-Dunk Redkneck Transplant"
CRATE = Cant Really Appreciate The Engine..
http://www.ford-trucks.com/forums/619321-russ-east-vs-west-3.html
  #34 (permalink)
Old 05-09-2008, 09:04 AM
I think pulling the cam is beyond my ability. I will have to get someone to do that for me.
Another question:
When I have the cam pulled, if the cam gears are found to be damaged, what new cam/lifters would you recommend me ordering? Below are my current engine specs:
Block: 390 bored .030 over
Heads: C3AE-6090C (new seats, valves, and guides)
Pistons: TRW pistons (.030 over) L2291Fs
pistons to be below deck was .012".
Current Cam: Speedpro
Intake Exhaust
.050 Dur. 214 224
SAE Dur. 292 302
Cam Lift .295 .310
Valve Lift .510 .536
Lobe Ctrs 107 117
Lash Hyd
Rods: stock
Crank: stock
Headgasket: standard gasket that came in SpeedPro kit
Intake: Edelbrock Performer (gasket matched)
Carb: 600 cfm edelbrock with electric choke (non emission)
Distributor: D.U.I
  #35 (permalink)
Old 05-09-2008, 01:05 PM
Update:
I pulled the lifters and cam. The cam and lifter look fine to me, but I am going to take them to my local autoparts for a second opinion (have them inspect the cam gear). I realize this will only be a visual inspection and am curious to hear your input on just purchasing a new cam to eliminate the problems 77Bronco experienced.
  #36 (permalink)
Old 05-09-2008, 01:12 PM
77 Bronco is starting off with a positive reputation.
Lance Hogan....You will see a definate difference in the way the cam gear looks. It shouldn't have chewed up the cam gear all the way around. If you look at the cam gear all the way around and it looks like the teeth are nice and not marked up I'd say your ok. Can you post a picture in your gallery? But since it did destroy the distributer gear, I'd clean that engine thouroughly even if you think the metal didn't get too far. Better safe now than really sorry later. Just my 2 cents.
__________________
1968 Ford F-100 Custom Cab, 2WD, 8' Bed, 360 FE (5.9L)
3 Speed on the tree converted to 4 Spd Auto
Power Steering conversion
Bought 2/08 with 69,300 miles.
  #37 (permalink)
Old 05-09-2008, 04:12 PM
Redmanbob's Avatar
Quote:
Ditto,
take the first few lifters down and see if you find anything in them. It hasnt been started so the lifter address isnt issue at this point. But yeah hell the thing is out and 50% apart.. save yourself so undue stress and cursing. Figure the dog will love you a little more if he doesn't get kicked
__________________
66 F100 352 V8
  #38 (permalink)
Old 05-09-2008, 04:49 PM
I took the cam and damaged distributor to my local machine shop for inspection. The machinist examined the cam and found one small spot that he filed . He believes the cam is ok and ready for installation. Further, he too wondered what caused the cam gears to not mesh correctly. I showed him the distributor and he said "that isn't a 390 distributor, that is a 302 distributor". I explained to him that I took the word of the person who gave me the distributor that it was the correct one. Lesson learned!!
I have cleaned the entire block. Also, I installed the cam and timing set and hope to have the motor back together by early next week.
  #39 (permalink)
Old 05-11-2008, 12:01 AM
krewat's Avatar
krewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud of
That's good news
At least you have a root cause.
Let us know how it goes every step of the way.
__________________
- art k. - Moderator for the Superduty, V10, and FE-series forums
'01 F250SD SC SB XLT V10 4x4 auto 3.73 eBay headers and y-pipe
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 4x4 435NP 205NP deceased!
I've been wrong before, I'll be wrong again. Just wait and see.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
