Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #16 (permalink)
Old 05-08-2008, 11:20 AM
Lance Hogan is starting off with a positive reputation.
Redmanbob,
I can not confirm that the distributor was completely seated. It is a "old junk" distributor that I was using that I thought was completely seated, but after all that has occured, I am second guessing myself.
  #17 (permalink)
Old 05-08-2008, 11:22 AM
Redmanbob's Avatar
Humble servant of my Peni
Redmanbob is gaining momentum as a positive member of FTE.
I don't think you have any issue with the rod/main bearings as of yet. The engine hasn't fired over or seen enough sump to get those pieces traveling very far if at all. JMO
An easy cheap primer tool is a 3" long thin walled 1/4 drive 1/4" socket and a 6" extension connetcted to a 1/2 inch drill. Takes the junk dizzy completely out of the equation and you can see down the hole to see if the oil starts coming in from the cam gallery.
__________________
66 F100 352 V8
"Po-Dunk Redkneck Transplant"
CRATE = Cant Really Appreciate The Engine..
http://www.ford-trucks.com/forums/619321-russ-east-vs-west-3.html
  #18 (permalink)
Old 05-08-2008, 11:31 AM
Bear 45/70's Avatar
Bear 45/70 is gaining momentum as a positive member of FTE.Bear 45/70 is gaining momentum as a positive member of FTE.
The oil filter is suppose to catch all those pieces, that's it job. I would suspect the bearings are fine.
__________________
Bear 45/70
Gimp Racing
Don't pick a fight with an old man. If he is too old to fight he will just kill you.
  #19 (permalink)
Old 05-08-2008, 11:52 AM
krewat's Avatar
krewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud of
Quote:
Originally Posted by Lance Hogan View Post
On another note, I am concerned that when I rotated the assembly while checking the cam gear that I contaminated my rod bearings. Could this be possible??
Not likely - it would have to go through the oil pump and the filter before it would get to the rod bearings.
Weird that the entire bottom half of the dizzy gear is gone. Very weird. If the distributor locked up, it wouldn't be all the way around the gear, it would only be where it meshed with the cam.
__________________
- art k. - Moderator for the Superduty, V10, and FE-series forums
'01 F250SD SC SB XLT V10 4x4 auto 3.73 eBay headers and y-pipe
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 4x4 435NP 205NP deceased!
I've been wrong before, I'll be wrong again. Just wait and see.
  #20 (permalink)
Old 05-08-2008, 11:55 AM
Redmanbob's Avatar
I think the dizzy was resting on the cam gear and when it tried to mesh it couldn't.. hence what we have here today "a failure to communicate"
__________________
66 F100 352 V8
  #21 (permalink)
Old 05-08-2008, 01:02 PM
Another question. Since I am pulling the motor and will be removing the intake and oil pan, should I remove the timing chain cover to see if metal entered that area?
  #22 (permalink)
Old 05-08-2008, 01:13 PM
Redmanbob's Avatar
Frankly I wouldn't bother with the intake unless you turn it upside down. But I could be wrong.. basically there is just the boss for the dizzy which is ? .5" wide and when the pan is dropped you have access to clean that up if there is anything resting in there (which surely there is)
__________________
66 F100 352 V8
  #23 (permalink)
Old 05-08-2008, 02:12 PM
77 Bronco is starting off with a positive reputation.
I did the same thing to a small block ford (351W) and it ended up taking the cam gear with it. Engine ended up eating cams ever since then. Not trying to worry you. Just make sure you check the cam gear very closely.
__________________
1968 Ford F-100 Custom Cab, 2WD, 8' Bed, 360 FE (5.9L)
3 Speed on the tree converted to 4 Spd Auto
Power Steering conversion
Bought 2/08 with 69,300 miles.
  #24 (permalink)
Old 05-08-2008, 03:07 PM
FFR428 is gaining momentum as a positive member of FTE.
Question. When you installed the intake did you seat the distributor with it? In other words was the distributor installed when you torqued the intake down?
__________________
68 Mercury Cougar XR7, 200 6 cyl.
  #25 (permalink)
Old 05-08-2008, 05:07 PM
FFR428,
I had not purchased a distributor at the time the intake was installed. So, the distributor was not seated at that time.
  #26 (permalink)
Old 05-08-2008, 06:06 PM
Update:
I removed the oil pan and intake finding metal particles on top of lifters, on top of oil pump, and the top of the middle of my double sump pan. I believe all the particles are accounted for.
My next step is to obtain new intake manifold gaskets and oil pan gaskets and begin the reinstall process.
What a day!!
  #27 (permalink)
Old 05-08-2008, 06:16 PM
Ok be sure to seat/install it when your installing the intake. Makes things easy in the long run. Also put a new rubber grommet on it if at all possible.
Good luck.
__________________
  #28 (permalink)
Old 05-08-2008, 06:20 PM
How did the cam gear look? ok?
__________________
  #29 (permalink)
Old 05-08-2008, 07:14 PM
Redmanbob's Avatar
I for the life of me cant figure how particles ended up on top of the lifters, even went out to reference a bare block to make sure I wasnt crazy. There is a journal between the gear and any upward access. The base of the lifters are subject to mess. And after looking at that.. hmm if you got it out, I dunno that I wouldn't pull the cam and lifters if not all of it apart and give it a bath. Probably just overkill but beats doing this same **** or worse a few days from now??????????
__________________
66 F100 352 V8
  #30 (permalink)
Old 05-08-2008, 07:15 PM
I agree Redmanbob. Been there done that....never want to again.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
