Oil Pan Torque Specs
on
1 Post
Can someone with the Shop Manuals for an 89 F250 help me out? I need the torque specs for the oil pan, as in how many ft/lbs and the proper sequence for torquing the bolts. I need to replace my pan gasket and my Haynes manual does not have this information. Here's what I have:
1989 F250 4X4, 5.0l, neoprene one piece gasket. If you need anymore info, please let me know.
Thank you.
Roger Lane
Test Analyst
Sr. Automated Test Engineer
IBP, Inc.
Roger.Lane@ibpinc.com
Thank you.
Roger Lane
Test Analyst
IBP, Inc.
Hi Roger
Condensed information from a Haynes Manual
Oil pan bolts:
1/4" bolt - 84 to 108 in-lbs
5/16" bolt - 108 to 132 in-lbs
Apply a thin even coat of RTV sealant to both sides of the gaskets and a small amount of RTV sealant at each mating joint.
(Later models use a one piece gasket.)
Tighten the bolts starting from the center, and working out in each direction.
Cheers
Davie
Vancouver BC.
Oil pan bolts:
Cheers
Davie
Vancouver BC.
Jolly Roger Joe
34
03-06-2017 01:04 AM
