Oil Pan Torque Specs - Ford Truck Enthusiasts Forums
Old 06-06-2000, 07:11 AM
lanero lanero is offline
lanero is starting off with a positive reputation.
Can someone with the Shop Manuals for an 89 F250 help me out? I need the torque specs for the oil pan, as in how many ft/lbs and the proper sequence for torquing the bolts. I need to replace my pan gasket and my Haynes manual does not have this information. Here's what I have:
1989 F250 4X4, 5.0l, neoprene one piece gasket. If you need anymore info, please let me know.
Thank you.
Roger Lane
Test Analyst
Sr. Automated Test Engineer
IBP, Inc.
Roger.Lane@ibpinc.com
Old 12-28-2000, 01:18 PM
davie davie is offline
davie is starting off with a positive reputation.
Hi Roger
Condensed information from a Haynes Manual
Oil pan bolts:
1/4" bolt - 84 to 108 in-lbs
5/16" bolt - 108 to 132 in-lbs
Apply a thin even coat of RTV sealant to both sides of the gaskets and a small amount of RTV sealant at each mating joint.
(Later models use a one piece gasket.)
Tighten the bolts starting from the center, and working out in each direction.
Cheers
Davie
Vancouver BC.
Old 12-28-2000, 05:24 PM
Supercab Supercab is offline
Supercab has a very good reputation on FTE.Supercab has a very good reputation on FTE.Supercab has a very good reputation on FTE.Supercab has a very good reputation on FTE.
Torque Specs Needed....'92 F350 460 spark plug and trans pan SoCalAngler 1987 - 1996 F150 & Larger F-Series Trucks 0 03-30-2014 01:01 PM
95 ford f150 oil pan bolts torque caclark1992 1987 - 1996 F150 & Larger F-Series Trucks 2 12-04-2011 12:18 PM
Best Lube for NP435 lanero Oil & Lubrication 7 09-20-2002 11:34 PM
T18 Weight? lanero Clutch, Transmission, Differential, Axle & Transfer Case 2 07-26-2001 09:05 PM
Need Torque Specs on Oil Pan Bolts safer 1987 - 1996 F150 & Larger F-Series Trucks 4 02-04-2001 11:46 AM
Tags
302, 460, 50, bolt, f150, ford, oil, pan, spec, specifications, specs, tork, torque, tourqe, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
