Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Cooling, Heating, Ventilation and A/C
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-07-2008, 06:53 PM
RickF350's Avatar
RickF350 is starting off with a positive reputation.
Condenser vibrates and makes noise??
Sometimes the condenser in my 05 F350 will vibrate and make a grinding sound. So far this only happens after the truck has sat for a few days or is cold (ie 20F) and only during the first second or two of the first compressor cycle. If you want to see what I'm trying to explain, PM me your E-mail and I'll sent you a video of it.
So far Ford has cleaned the lines and or orifice, adjusted the compressor clutch and took out some refrigerant ,but it still vibrates. Tomorrow they want to overcharge the system.
So, does anyone know what is wrong my AC?
__________________
05 F350 XLT SC LB SRW 6.0L PSD
04 RX-8 Touring 1.3L rotary
03 KTM 525 EXC
94 RX-7 PEP 1.3L rotary
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-16-2008, 12:55 AM
bustech81 is starting off with a positive reputation.
I had an issue with this problem last year, however it was on an e- chassis. what was happening was the pump was slugging liquid. only until the pump built some heat did the liquid flash. In large bus systems we implement things like liquid line solonoids and condenser check valves to keep this from happening. what i did to correct was replace the accumulator/drier, then two new reed valve plates in the pump. ignored recomended charge level and did the old fashoned way. got compressor superheat to 12 degree's with 20 degrees of delta t. Don't remember exact charge however. havent had a problem since. good luck
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
