From what my Grandpa's told me when he does this, the extra gap in the circuit makes the spark hotter and the plug more able to fire if fouled. If your engine smooths out like you're saying, it could mean that the idle is a little rich. But then aren't #1 and 6 supposed to be leaner being furthest from the carb? Or is it the other way around?
It could also mean that oil is getting in the combustion chamber and fouling the plug. Maybe past the rings or the intake valve seal. What weight oil are you currently running? Does the engine use any? You could try the next heavier grade on your next oil change. Shouldn't hurt anything in any case.
There used to be little spacer adapter things that you could screw into the head and then screw your spark plug into essentially making a precombustion chamber. They were supposed to help prevent plug fouling from what I understand. I don't know if you can still get them or not, but it seems to me that they only treat the symptoms and not the ailment.
Anyway, if your new plugs foul up again (and I'd say it a distinct possibility), I don't really know how to tell if its oil or gas thats causing it. Maybe someone else does?
