Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-07-2008, 06:10 PM
pipman76 is starting off with a positive reputation.
Thumbs up cam lift??
whats the max lift u can run with stock d3 heads without going adjustable?
i found a couple of mild cams but didnt know if the lift was to much lunati has a bracket II cam with 280-290 dur and 516 intake lift and 543 exhaust power band is 1500-5500
summit has thier own brand cam that has like 286-296 dur with 501 lift on both sides powerband is 2000-4500
any suggestions welcome
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-09-2008, 08:16 AM
385seriesHemi is gaining momentum as a positive member of FTE.
I am going to run .542/.552 lifts with my D3s and if I remember right someone said dont go over .600 though. The cam I am using will be a Voodoo from Lunati.
__________________
Gearhead for life slammin' iron & chrome right to the bone!
1992 F150 300-6ci
1976 Cadillac Coupe Deville 500ci
1998 Dodge Ram 4x4 318ci
1970 Chevy Nova SS 360ci
  #3 (permalink)
Old 05-11-2008, 04:31 PM
darrin1999 is starting off with a positive reputation.
stock springs will bind somewhere around .510 so you better be changing springs/retainers for any more than that.
__________________
drive trane parts may strand you, but suspension parts can kill you.
if you cant pay cash for it, you cant afford it.
  #4 (permalink)
Old 05-11-2008, 06:40 PM
i wasnt gonna use stock springs i would buy matching springs for the cam.the voodoo cam seems like alot of lift for non-adjustable heads are u changing valvetrain to adjustable
  #5 (permalink)
Old 05-11-2008, 10:45 PM
65f100_352 is gaining momentum as a positive member of FTE.
What would be the max lift on a stock motor without piston to valve contact?
  #6 (permalink)
Old 05-12-2008, 10:09 AM
werneil is starting off with a positive reputation.
i think with the cams you have mentioned with proper valve springs, retainers, lifters etc.
you should not have any problems with non adjustable valve train, as long as basic clearances are within specs. eg. valve height, pushrod length, rocker arm ratio etc.
always check piston/valve clearance
  #7 (permalink)
Old 05-12-2008, 06:35 PM
ok thanx for the help
  #8 (permalink)
Old 05-12-2008, 09:06 PM
greenhighboy's Avatar
greenhighboy is starting off with a positive reputation.
I built a motor for a friend over two years ago using the VooDoo cam that 385Hemi mentioned with non adjustable D3 heads. It has had the guts ran out of it, wide open ALL the time and never had one problem. I did take my time and found the correct pushrod length and used the correct springs.
  #9 (permalink)
Old 05-19-2008, 12:38 PM
*70F250* is starting off with a positive reputation.
hey guys, sorry to kinda hijack, but a freind is offering me a comp cam for $50
i have a stock 460. except a edelbrock intake manifold and a holley 750 dp. the 750 is actaully doing pretty good. doesnt seem too big
but anyway, this cam is for a boat engine..does it matter?
COMP CamsŪ - Cam Details
thats the link for the cam. do you think it will work ok? it says i need other springs...i can get those if you guys think it will be good. later planes are l&l fenderwell headers.
the 460 is swapped into a '79 f150 custom 4x4. i use it mainly for 4x4ing and some towing. thanks guys
__________________
79' F-150 custom 4 x4
460-C6
NP205 DANA 44/FORD 9" - 4:11
37" michelin XML's
Rough Country 4" suspension lift
Custom made light bar
4 Hella 500s
  #10 (permalink)
Old 05-19-2008, 02:15 PM
460me's Avatar
460me is starting off with a positive reputation.
This is the one that I used along with springs and retainers:
CraneCams
  #11 (permalink)
Old 05-20-2008, 06:33 AM
HI, 70/f250, that cam should work fine with what you have, maybe improve the exhaust
system will be even better. remember changing 1 part means changing other parts to
make it work better see ya NEIL
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
