Original Rims on e-Bay - Ford Truck Enthusiasts Forums
Old 05-07-2008, 06:35 PM
Col Flashman's Avatar
Col Flashman Col Flashman is offline
Col Flashman has a very good reputation on FTE.Col Flashman has a very good reputation on FTE.Col Flashman has a very good reputation on FTE.
For the individual that wanted Original Rims for his truck, I believe these will work.
eBay Motors: hot rat rod ford 15"steel wheels jeep f100 (item 280224222287 end time May-11-08 18:09:31 PDT)
Old 05-08-2008, 10:29 AM
GreatNorthWoods's Avatar
GreatNorthWoods GreatNorthWoods is offline
GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.
Yes, they will bolt on and take the original hubcaps but I'd verify if they are really 15's before bidding on them. At only 4.5 inches wide they could be 16's. Most of the 15's I'm familiar with are wider than that...
Old 05-09-2008, 02:14 AM
lewislynn lewislynn is offline
lewislynn is new and has a neutral reputation at this point.
Another thing to consider is the size of the center (hub) . I recall using (50's) Plymouth wheels on a (50's) Ford or Ford wheels on a Plymouth. Anyway,the center hub was too large causing stress cracks on the lug holes. I heard them creaking first.
Old 05-09-2008, 02:21 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Where are the clips (mount on inside of wheel center), or tabs (outside of wheel center) to mount hubcaps?
No see um...
Some Ford hubcaps are called innies, because they snap into clips located inside the wheel center.
Some Ford hubcaps are outies, because they snap over tabs mounted outside the wheel center.
I see no innie clips or any place to mount them on these wheels. The clips were riveted to the wheels.
Where are the tabs for outie caps?
IMO, no way to mount hubcaps-these are not Ford wheels..these are prolly Jeep wheels-they did not used hubcaps originally (1940's/1950's).
1948/56 & 1957/63 truck parts catalogs do NOT show any 15" wheels that are 4 1/2" wide. 5" is the narrowest width listed (there is a 16" wheel that's 4 1/2" wide).
1949/59 passenger car wheels are 5" wide, the bolt pattern is 4.50."
Most 1948/66 F1/F100's used innie hubcaps.
1948/56 hubcaps are innies, the diameter isn't listed, but I've owned 3 1956 F100's, so I know the caps (B3C-1130-A-red or 6A-1130-A-blue letters) are innies only.
1957/60 F100 hubcaps are innies = 9 5/8" diameter / Most 1961/66 F100 hubcaps are innies = 9 1/2" diameter.
Old 05-09-2008, 09:35 AM
If you look closer you will see the nubs on the inside. That's why I said they would accept original hubcaps...
Old 05-09-2008, 12:29 PM
I put my nose to the 'puter screen and still can't see them, mebbe it's my eyes, they're 63 yers old!
At 4 1/2" inches wide, the wheels are prolly 1939/48 car.
Old 05-10-2008, 09:21 AM
No big deal...my eyes are older than yours! Wouldn't 39-48 wheels be 16 inch?
Old 05-10-2008, 11:25 AM
bobj49f2's Avatar
bobj49f2 bobj49f2 is offline
bobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud of
They don't look like Ford to me. I can kind of see the inner nubs but they aren't as pronounced as Ford.
Old 05-10-2008, 09:46 PM
Bob at warsaw's Avatar
Bob at warsaw Bob at warsaw is offline
Bob at warsaw is starting off with a positive reputation.
No Bids so for, maybe there are alot around
Old 05-11-2008, 09:07 AM
r_reed's Avatar
r_reed r_reed is offline
r_reed has a great reputation on FTE.r_reed has a great reputation on FTE.r_reed has a great reputation on FTE.r_reed has a great reputation on FTE.r_reed has a great reputation on FTE.r_reed has a great reputation on FTE.
i have a set of 4 original 16" wheels from my '49. they have the "innie" bumps. i'll probably sell them locally but i have no idea what to ask for them. if they are in decent useable condition are they worth $5? 10$, more?? i want to pass them along but i don't want to give them away. sorry if this is considered a hijack. dick r.
Old 12-25-2008, 07:57 PM
village7 village7 is offline
village7 is starting off with a positive reputation.
Rim Interchange
I am putting a '94 explorer rear end with drums and front discs on the straight front axle under my '50 F-1, with the the bolt pattern being 5x4.5
1) Are there any stock rims available that are 16" 5x4.5? If there is such a thing would they accept the hubcaps and trim rings from the stock 16" 5X5.5 rims? If there is a 16" 5x4.5 rim what widths would be available?
2) I know there is a stock 15" rim, 6" wide, 5x4.5. Is there a stock 15" 5x4.5 rim available in a 8" width? Would this combo accept the same kind of trim rings and hubcaps?
Old 12-25-2008, 08:11 PM
Brian_B's Avatar
Brian_B Brian_B is offline
Brian_B is gaining momentum as a positive member of FTE.
They are removed for whatever reason from fleabay.
It took me a while to find the set that is on my truck. Most of them I got for free. I think I paid $5 for one out of the 5.
I assume they are the proper wheels anyway. I guess Bill will tell me soon enough.
They really need to be blasted and painted, but they are fine for now.
Old 12-25-2008, 08:55 PM
49willard 49willard is offline
49willard has a great reputation on FTE.49willard has a great reputation on FTE.49willard has a great reputation on FTE.49willard has a great reputation on FTE.
No see um...
Bill, This thread sent me out to measure the wheels that I took off my 49 F-1. I know that they were not the original wheels since I wanted 15" wheels that took the original 49 hubcaps (nubs on the inside). I bought them in CA back in the 70's when I lived in Campbell. They are the 5.5" B C. I thought that the 15" came on the 46-48 Mercury. Well I went to measure them and three were 15 x 5 and one was 15 x 5 1/2! I ran those many miles not realizing the one odd width, in fact I drove the truck crosscountry in 1978 with the one odd wheel (see early pix in my gallery). Ignorance is truly bliss! So all that said, what were the two different wheel from?
Old 12-25-2008, 08:56 PM
These early 15" rims were also used on the 6' utility trailers that U-Haul and everyone else used to rent.
Brian, it looks like it's about time to do another Col. Flashman special.
He painted his Merc M100 with RED Rustoleum...didn't you use the same stuff?
Looks to be the same shade of red as the Colonel's truck...which has been in my driveway and garage, and I have the oil spots to prove it!
Merry Christmas, Happy New Year.
Old 12-25-2008, 09:07 PM
Brian_B's Avatar
The front fenders and the roof were polka dotted with all sorts of colors when I bought the truck. I spray painted them red. Just the .99 cheap stuff from wal-mart. It was supposed to be temporary.
I do have the drivers side front stripped, patched, and in epoxy primer now.
I ended up broke and now its wet and nasty, so they will stay that way until spring.
ford truck hood scoop on ebay bigwin56f100 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 03-07-2015 08:29 AM
1950 F1 on EBay 1950FordF1 1948 - 1956 F1, F100 & Larger F-Series Trucks 12 01-29-2015 04:57 PM
A wild 51 in Aussie land aussiecowboy 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 05-05-2013 10:41 AM
Craiglist '50 F100 LOL Jeff and Nicolle 1948 - 1956 F1, F100 & Larger F-Series Trucks 25 07-05-2012 04:53 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
