Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford Inline Six, 200, 250, 4.9L / 300
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-07-2008, 05:14 PM
Duke58f100's Avatar
Duke58f100 is starting off with a positive reputation.
Identifying my inline 6
Ok, I know you all will think this is lame but I need to find out what 6 I have in my 58. Think it's been swapped since the guy said so. Not sure where the numbers are and then where to go to decipher it. I have searched the net and haven't found anything on it. Any help would be great!
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-07-2008, 06:05 PM
85e150six4mtod has a good reputation on FTE.85e150six4mtod has a good reputation on FTE.
Pics?
Look for numbers above the starter.
Intake and exhaust are on what side?
Does the intake bolt to the head or is it cast as one?
There are some noticable diffs between the older 223 and newer 240/300.
Here are some pics of a built 300, modified, but you can see the valve cover and how it is shaped.
http://www.ford-trucks.com/user_gall...=88361&width=0
  #3 (permalink)
Old 05-07-2008, 06:06 PM
AbandonedBronco is starting off with a positive reputation.
Several starting points to look at is what side of the engine the exhaust manifolds are on and how they are attached.
EDIT: Looks like I was typing when you were typing.
__________________
1981 Ford Bronco 300 1bbl. 4 speed Manual w/OD. Stock!
Boise, Idaho
  #4 (permalink)
Old 05-07-2008, 09:12 PM
Duke58f100's Avatar
Ok back from the depths of grease!! More grease on that number but got er off,
engine #e1te6015 aa Intake bolts on like your 300, also on the pass side
  #5 (permalink)
Old 05-07-2008, 09:36 PM
Duke58f100's Avatar
Here's a pic, I think i figured it out once I found the casting #, I think it's an 80's 300ci? Thanks for your help locating that #
  #6 (permalink)
Old 05-07-2008, 09:40 PM
Silver Streak is gaining momentum as a positive member of FTE.
The first two digits of the casting number say that it was first meant for production in 1981. That is definitely either a 240 or 300. The only way to tell for sure which is to measure the stroke.
__________________
1990 F-150XLT Lariat Stillon the original engine with no squeaks or rattles at over 300k miles
4.9/M5OD/3.08
16.89@77.09
145 rwhp, 272 rwtq
2001 Lightning #127
13.18@104, no chip, no pulley, no nitrous
Confuscious say "Man who have no use for jackstand have promising career as jackstand".
  #7 (permalink)
Old 05-07-2008, 09:53 PM
Duke58f100's Avatar
I am new to all of this as you have probably figured out but how would I measure the stroke??
  #8 (permalink)
Old 05-08-2008, 12:40 AM
Ford_Six's Avatar
Ford_Six is a splendid one to beholdFord_Six is a splendid one to beholdFord_Six is a splendid one to beholdFord_Six is a splendid one to beholdFord_Six is a splendid one to beholdFord_Six is a splendid one to beholdFord_Six is a splendid one to beholdFord_Six is a splendid one to behold
It's a 300, the 240 stopped production in 74 or 75, and generally people replace the 240 with the 300. It'd be really odd to find a 240 crank, rods, and pistons in an 80's 300 block.
If you want to check the stroke, use a dowel about a foot long down a spark plug hole. Mark it at the piston's highest point, and at it's lowest point. If it's about 4" difference between the marks, it's a 300. If it's a little over 3", then it's 240 innards in there.
__________________
Jared
Quote:
Originally Posted by Tadao Ando
"If you give people nothingness, they can ponder what can be achieved from that nothingness."
FTE Guidelines
  #9 (permalink)
Old 05-08-2008, 07:55 AM
I agree it would be strange, but I wouldn't put it past anyone.
__________________
4.9/M5OD/3.08
16.89@77.09
145 rwhp, 272 rwtq
2001 Lightning #127
  #10 (permalink)
Old 05-08-2008, 09:07 AM
NumberDummy's Avatar
Ford Parts Guru
NumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant future
E1TE = 1981 / No 240's after 1974 / 240 stroke: 3.18" / 300 stroke: 3.98"
__________________
Bill / Retired Ford Partsman ~ 1962/97
Part number research: Trucks 1948/02 / Cars 1949/91
1963 Galaxie 500XL / 1965 F100 Styleside / 2008 Fusion
  #11 (permalink)
Old 05-08-2008, 11:51 PM
Bdox's Avatar
Iconoclast
Bdox has much to be proud ofBdox has much to be proud ofBdox has much to be proud ofBdox has much to be proud ofBdox has much to be proud ofBdox has much to be proud ofBdox has much to be proud ofBdox has much to be proud ofBdox has much to be proud ofBdox has much to be proud of
I was hoping to buy a 240 head for my 300. Does this mean that I have to have the head off in order to distinguish the differences?
My goal was to increase the compression by using the 240 head. Are the valves the same size in each of those heads?
__________________
It's only kinky the first time you do it!
Life is short, make fun of it !
Snowbunny for president!!
Bruce, Nevada Chapter
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
