there is a lot of info on that thread, read it all and have read through the half dozen other pages on other forums (those 30 page threads
) and there is still some info that was not real clear or not presented. These full valve bodies have only been mentioned a few places and seemed like the service was pretty much glossed over.
I asked donnie to provide a list of modifications, upgrades, and new items that come with each valve body. This is what he sent me:
Rebuilt 4R55E,4R44E,5R55E,5R44E valve bodies - Each solenoid is individually
tested and flushed. All (4) shift solenoids get new o-rings. This valve
body is updated with the following Sonnax updates on every rebuild: large
ratio boost valve, 7 piece end plug kit with o-rings, TCC regulator sleeve
and elevated pressure regulator spring. Other updates and modifications are
made to the valve body as needed. The pressure relief TSB from Ford is
installed in the valve body to prevent hard part damage from excessive line
pressure. The separator plate is also modified to enhance shift
performance, provide adequate lube and address lock-up problems.
Modification of the separator plate prevents the use of a bonded plate. The
upper and lower valve body gaskets are replaced with new. Each valve body
is tested on a computerized tested machine to simulate driving conditions.
A 12 month unlimited mile warranty comes with the valve body.
-Remanufactured by Central Valve Bodies- Contact
donny@centralvalvebodies.com
Thank you,
Donny Lester
15551 S HWY 66
Claremore, OK 74017
(918) 341-0266 phone
(877) 341-0266 WATS
(866) 826-1847 fax
