Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Clutch,Transmission, Differential, Axle and Transfer Case
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #16 (permalink)
Old 05-12-2008, 10:28 PM
TheNomad is starting off with a positive reputation.
Quote:
Originally Posted by sclariat View Post
If you don't care about gas mileage....or tires....you'll have a heck of a lot of fun with 4:11's!!!
Smoke them tires
__________________
1979 F-150 Ranger 302.
1979 F-150 Ranger 460 in the works
So many dogs and yet so few subsonic 22s
NRA
TRSA
  #17 (permalink)
Old 06-13-2008, 12:34 AM
Well I found out what Gears the joker before me installed 2.75s thats pretty tall...
No wonder she was all ways a little slugish
__________________
NRA
TRSA
  #18 (permalink)
Old 06-22-2008, 02:42 PM
78F150XLT is starting off with a positive reputation.
If you truck was a 2wd, its got proboably 2:55 gears. My 78 F150 had that. Instead of going with a locker, and if u wanna have something alot lighter but stronger in the back, get a spool, or a mini spool. And 4:11's are awsome if you wanna hit that 60mil/hr on the 1/4 mile fast and smoke your tires super easy.
Another thing i noticed when i had my rear end appart when i stripped of the axle splines on a spider gear (good story behind that one hahaha) is the spider gear inside the pumpkin which dosnt have the clutches for the limited slip, it has about a 1/4inch lip which recesses into the shell of the pumpkin where the axle slides into. The spider thats on the side with the clutches has no lip because the clutches are about 1/4 inch thick total, same as the lip on the other spider, and the gear sits right up against the clutches. I was wondering, I'll try when I finish the motor, can you take out the clutches and the spider on that side of the pumpkin and put the same spider from the other side (non-clutch side) in place of where the clutch/spider gear was? Will it work? Would it act like a spool?
__________________
1995 F150 Reg. Cab, Long Box, 4X4.
7 inch Lift, 35/12.5/15 Micky Thompson Baja MTZ
4.10 gears w/lockers, AODE w/stage 2 shift kit, B&M shift plus
302 5.0L V8 w/GT 40 upper/lower intake, 65mm throttle body, ported H.O. Heads, cam, bored 30-over, Ram Air hood, headers, 3inch exhaust, MSD electronics
Black Projector Headlights/Black Euros
Custom Sound
  #19 (permalink)
Old 06-22-2008, 04:44 PM
That's going to be one for others to answer, I know very little about rear ends. I know, I was kinda shocked when the guy told me I had a 2.75 back there. but I guess in the long run its better. But on my new truck i'm working on the with the 460, I'm going with some faster gears and a posi like a auburn Posi lock.
I've come to find out that unless your truck lives 90% on its life on a strip or in the dirt a true locker is a nightmare to use on a truck that is mostly city driving..
__________________
NRA
TRSA
  #20 (permalink)
Old 06-22-2008, 09:20 PM
Well not entirely that bad... its just hard on the tires Ive found. I have a Detroit locker in my every day driver with 4:10's but im running 35' mud tires. In the winter, when the streets get icy, it gets a little interesting when you have a locker, it loves to slide out alot! haha
__________________
Custom Sound
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
