Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Bronco > Early Broncos (1966 - 1977)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-07-2008, 11:22 AM
gvrangr98 is starting off with a positive reputation.
Question Getting Her Started.....we hope...
here is what I know... my 1969 Bronco has a 1971 V8 302 in it. It has had a lot of "do it yourself" done to it. Mostly the carb is a four barrel and the electrical system is no where near factory. So the other day I took the Battery out of my 98 Ranger and hooked it up to the Bronco to see how far I'd get. Well when we turned the key all I heard was a "click" I don't know where the problem lies exactly but last my wife knew it started up great.(6 years ago.) It has been sitting for a while. So this weekend I plan to change up all the fluids, oil.. coolant...gear oil...everything. I'm going to pull and replace the plugs and wires, give her a knew air filter, fuel filter.
What I need is a wire diagram for the 1969 Ford Bronco. any body got that?? And also a diagram of what the 302 and all its components are "supposed to look like" where everything goes..what to where and so forth and so on..any one know this stuff??? or have it on a disk or on paper??? Help!!
__________________
1998 Ford Ranger XLT 4X4 KingCab Stepside
Vulcan V6 3.0 Automatic
Customized K&N Cold Intake
Customized 2.5 in. CatBack by "Lou's Custom Exhaust"
245/70r16 BFG OpenTrail T/A's
213,565 "New England" miles and climbing
1994 Saturn SC1
249,478 "New England" miles and running strong!
38 MPG (Daily)
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-07-2008, 01:45 PM
gjrock is starting off with a positive reputation.
No start
Single click is usually the starter or starter solonoid.Have someone tap the starter while tring to start.I will try and find some links to the info you requested.
  #3 (permalink)
Old 05-07-2008, 11:05 PM
RCrawler's Avatar
RCrawler is gaining momentum as a positive member of FTE.
Check your battery connections, including grounds. After 6 years, a lot of corrosion can accumulate and they can also become loose. If you have a test light, check for power on both sides of the solenoid when the key is turned. Check for power at the starter itself. Here are the diagrams for a 69
Jason
__________________
'93 F350 CC 4wd 7.3L 5spd, 240K miles
'69 Bronco SEFI 5.0, NP435, geared, locked...
'77 F150 4wd 351M, 435, 205
'79 F150 4wd lwb 400, 435, 205
"You can take the boy out of the trailer park, but you can't take the trailer park out of the boy."
  #4 (permalink)
Old 05-08-2008, 12:52 AM
nice. thank you.
__________________
1994 Saturn SC1
38 MPG (Daily)
  #5 (permalink)
Old 05-08-2008, 03:29 PM
GOOD NEWS!!! I have discovered that the problem is NOT the starter but infact it IS the ignition coil. We noticed that it is Lost/ Misplaced/ or Stolen! So AutoZone has them for around $20 some odd bucks. that is better than a $100+ starter and solenoid! I wish I could buy just one coil wire insted of having to buy a whole set of plug wires. That is a good electrical diagram but I'm trying to enlarge it so I can read it better.
Once I install the ignition coil, it should (hopefully) start right up. Well..at least it'll turn over.
any one else have any other ideas?
__________________
1994 Saturn SC1
38 MPG (Daily)
  #6 (permalink)
Old 05-13-2008, 10:31 PM
3406pack is starting off with a positive reputation.
The coil shouldnt have anything to do with it "just turning over".Double check your electrical connections or better yet check and see if it will turn over by hand first.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
