Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Bronco > Big Bronco (1978 - 1996)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-07-2008, 09:42 AM
1badbaker is starting off with a positive reputation.
New Member with Idle Question
Just wanted to start out by saying hello. I've been checking out the forum for a couple weeks now and it looks like there's a lot of good information around here. Now to the question...
I have a 93 Bronco XLT, I bought it about 5 years ago and have never had any major problems. For the past month or so, I've been having a rough, loping idle. It's bad enough that I can't start the truck and just let it idle without it killing itself. If I sit on the gas and keep it around 800-1000RPM it will still lope, but won't die. So, I'm wearing the hell out of my brakes, driving with two feet so I don't die at stops.
I put on a new alternator a few months ago, new fuel pressure regulator, fuel filter, serp. belt, PCV valve, and tensioner pulley within the past couple of months also. The plugs and wires are about two years old. I think it's the EGR valve or the vacuum lines. Has anyone had this problem? Any suggestions or ideas are appreciated, I'm about to lose my mind with this thing.
edit: almost forget, I have the 5.8L 351
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-07-2008, 07:40 PM
cajunland is starting off with a positive reputation.
Check your iac. its usually (not always) a good place to start with idling problems, also check to see if you have any codes. itll show up if is the egr or something related and point you in the right direction
__________________
Tim
'93 Bronco - 302; E4OD; 4in ProComp, 35" Rem. Mud Brute
  #3 (permalink)
Old 05-09-2008, 02:12 PM
offroadbronco is starting off with a positive reputation.
First pull the codes and stop throwing parts at it. Your CEL does not have to be on, there can be codes w/o a CEL. Most likely you fried your TPS (throttle position sensor) or your IAC (idle air control) is dirty and needs to be cleaned.
Advance Auto or Autozone will pull your codes for free, or you can do it yourself with a paperclip and counting a blinking light. You can also buy an OBDI reader....they are usually $30 bucks or so.
__________________
96 Bronco XLT, 302/E4OD
77 F-100 Custom, 300/C4, 2WD
  #4 (permalink)
Old 05-09-2008, 02:59 PM
UTfball68's Avatar
UTfball68 is gaining momentum as a positive member of FTE.
I had a problem like this with my 87 with a 302...My idle was rough...so I'd adjust the idle...worked for a little while. Then I had to two foot drive because it would surge at idle and then back off and die. Mine was simply an oxygen sensor. Maybe that's all you'll need.
__________________
'77 250 400 Boggers (show)__'96 350 CC 460 SSR's (work)__'79 Bronco 351M 35's (play)
Ben
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
