Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-07-2008, 08:53 AM
Cecil_Stringer's Avatar
Cecil_Stringer is starting off with a positive reputation.
2003 6.0 PSD - New PCM Flash - Banks 6-Gun Inoperable
I just got my truck back from the dealer about an hour ago where it was serviced and I have not had time to tinker with it yet.
I am hoping I can gain some insight from you before I start turning wrenches so-to-speak.
Scenario:
ICP Failure, EGR Failure, Battery Failure (both) and subsequent re-flash of PCM.
The Banks 6-Gun was disconnected prior to the service, then reconnected afterwards.
Now, with the Banks 6-Gun connected it is having issues shifting (automatic) and goes into "Safe-mode" (don't ask me, got that term from the mechanic).
Apparently, with the Banks 6-Gun connected after the re-flashing of the PCM it would NOT go past 65MPH, was shifting erratically, slipping into neutral from 4th and was flashing the "Over Drive" signal on the dash.
Is there something I need to do to get the Banks kit back on-line and operational other than just plugging it in.
It has been in the truck for about 18 months without a hiccup.
I have left it on setting #6, as it is right now.
For now, the Banks kit is disconnected and the truck is running fine (just weak relative to when it has the Banks kit operational).
Thanks guys, I always appreciate your help.
Cecil
FYI - After having the additional power from Banks no longer available..... ole girls seems like a "pig"
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-07-2008, 12:50 PM
gtdan01 is starting off with a positive reputation.
Have you checked if there are any updated firmares you can download onto the banks? Maybe it doesn't work with your new computer code.
__________________
2004 6.0 CC Fx4 XLT
  #3 (permalink)
Old 05-07-2008, 05:11 PM
Power Smoker is starting off with a positive reputation.
the torqshift transmission has built in adaptive learning. It learned the stock power level shifting so to make it work right you need to disconnect the batteries for a full 15 minutes, preferrably with the light switch on to reset the trans. learn mode. then reconnect the batteries and it should shift fine. this is a very common problem.
  #4 (permalink)
Old 05-07-2008, 05:47 PM
Quote:
Thanks!
What do you mean by:
"preferrably with the light switch on to reset the trans. learn mode."
  #5 (permalink)
Old 05-07-2008, 10:50 PM
Momorris is starting off with a positive reputation.
Turn your lights on and then disconnect the batteries, this will drain all the power in the electrical system.
Good advice Power Smoker. Rep points given.
Cecil, let us know if this worked for you.
__________________
2005 F250 KR CC 6.0L
DashDAQ - soon to be Phalanx Monitor
ARP headstuds
Silverline Turboback
SCT X3...Spartan and Innovative tunes
DFuser Coolant Filter
  #6 (permalink)
Old 05-08-2008, 04:13 PM
Thanks guys!!!
I spoke with a tech from Banks.
He said it sounded like a bad connection and that there was NOT a "update" that they provide.
He told me to validate a particular connection that sends a signal to the torque converter (Ford - brown w/ orange strip connects to a Banks - solid grey wire).
He said then disconnect the batteries, turn on the lights to drain any remaining charge, let it sit for 15 minutes or so (sound familiar ;-) ). Then reconnect the Banks kit, then the batteries. He said turn the key on but not to start the truck and check for a fault signal on the Banks device (Green is good..... Red & Green equals fault).
Gonna try this tomorrow..... hope it works.
Also read on another board that FORD was flashing the PCMs with a strategy that disallows the programmer signals. Thus making it so it will NOT work with a programmer. Something about the warranty on the 6.0 PSDs was generating too many claims.
If this is the case (the FORD flash scenario), can I revert back to a previous flash?
My warranty is up next month and I would prefer to have the additional HP & torque. :-)
Thanks again.
  #7 (permalink)
Old 05-08-2008, 04:22 PM
Kepler4's Avatar
Kepler4 has much to be proud ofKepler4 has much to be proud ofKepler4 has much to be proud ofKepler4 has much to be proud ofKepler4 has much to be proud ofKepler4 has much to be proud ofKepler4 has much to be proud ofKepler4 has much to be proud of
The "Ford anti-tuner flash" sounds like an urban legend to me. Probably the same folks who thought the Blair Witch Project was real. Don't let 'em get to you!
Take a gander through the 6.0 Tech sticky thread at the top of this forum and you'll find all kinds of tips and tricks. Lots of info from guys still here and guys from days gone by... like this: http://www.ford-trucks.com/forums/41...mer-users.html
__________________
Russ
05 F250 Lariat 4X4 6.0
Bilstein leveling coils & shocks, 35" Toyos, ARB lockers, ARP studs, MBRP cat-back, Reunel front bumper, Warn 12K winch, Ravelco & Lojack
Tows our 07 WW FSC 2800
Join the So Cal/Hawaii Chapter *HERE*
  #8 (permalink)
Old 05-17-2008, 12:00 PM
After re-connecting the Banks kit, validating the connections and following the directions of the Banks tech, it did exactly what the Ford tech described.
It was shifting erratically and neutral dropping, falling on it's nose and just basically having a ton of tranny related issues.
I called Banks back, they reminded me of the "Learn Mode" that takes place.
I re-did that and loddie-dah!
All systems are a go!
I was able to drive it 50 miles one morning (from the house, to my kids school, ten to work) and averaged 18.1 MPG!
And for a truck with 37" tires and 4.88 gears, that's pretty darn good.
Thanks for all the feedback and suggestions.
For now, we are back in business. :-)
  #9 (permalink)
Old 05-18-2008, 07:18 PM
Sarge261 is starting off with a positive reputation.
Ciecel,
What level do you run your Banks on. I have never seen 18 MPG with my truck and I have 285's on mine?
Sarge
__________________
2006 F-350 PSD Lariat Crew FX4 ALL BLACK
Banks Techni Cooler
Banks Big Mouth Intake Pipe
Banks High Ram Intake
Banks Monster Exhaust Turbo Back
BD Diesel Exhaust Brake
BD Diesel Torque Converter Pressure Controller
Air Ride Air Bags
Deep Sump Trans and Rear Diff. Pans
No-Shrink Tonneau Cover
  #10 (permalink)
Old 05-18-2008, 09:46 PM
Quote:
Originally Posted by Sarge261 View Post
Ciecel,
Sarge
I leave it on level 6.
To get the 18mpg, I was driving very conservative.
It has normalized to between 15.5 and 16mpg after a few hundred miles.
  #11 (permalink)
Old 05-19-2008, 06:56 AM
tex25025's Avatar
tex25025 is gaining momentum as a positive member of FTE.tex25025 is gaining momentum as a positive member of FTE.
Is that hand calculated or computer calculated? Tuners are notorious for fooling the system even if your driving habits matched what they computer "thinks" they are.
__________________
'06 6.0L Turbo Diesel King Ranch DRW 4.30 Gears
Spartan Stage 1 Towing Injectors
Spartan 64mm Non-VGT Turbo
Fluidampner
Headstuds
SCT w/Spartan tunes(including FICM tuning)
Fuel Regulated Return
FASS 150/180
5" Straight-Piped MBRP Exhaust
Tranny, EGT, Boost, and Fuel PSI C2 Gauges
Water Temp, Oil PSI, Volts Antique Beige Gauges
  #12 (permalink)
Old 05-19-2008, 12:36 PM
Quote:
That is solely off the on-board display.
If nothing else, it is a good relative comparison.
From 12mpg, up to 18mpg, averaging around 16mpg.
  #13 (permalink)
Old 05-19-2008, 05:03 PM
tex25025's Avatar
Actually it's not. I'm getting 13.8 mpg consistantly(hand calculated) and yet my computer is telling me that I should be getting 19.3 and it used to tell me I was getting 14.6. I wouldn't trust the on-board computer at all, particularly after having put a tuner to it.
__________________
Fluidampner
Headstuds
FASS 150/180
  #14 (permalink)
Old 05-20-2008, 09:47 PM
How are you "hand calculating" MPG?
  #15 (permalink)
Old 05-21-2008, 07:59 AM
King of the Road 04 is starting off with a positive reputation.
Total miles divided by total refill gallons. Best if the tank was filled to the brim before, and then done again to get as close as possible to an accurate measurement. But, nevertheless, this method is still a lot more accurate than the lie-o-meter.
__________________
2004 F-350 4X4 DRW CC BLACK with SPORT PACKAGE
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
