Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Brakes, Steering, Suspension, Tires, & Wheels
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-07-2008, 08:17 AM
philn is starting off with a positive reputation.
98 Exp. ABS engaging on hard right turns
I have a 2 wheel drive 98 Expedition that has no fault codes from ABS, however, when turning hard right the ABS engages and takes nearly all of the braking away. I replaced the rear speed sensor with no results. Have temporarily disconnected power to ABS module to kill ABS until I can fix problem. Wife has nearly bought several cars with the ABS engaging on dry pavement at low speeds! The strange things is, happens only in hard right turns at slow speeds. thanks for the help.
'98 Ford Expedition 4x2 120K miles
'02 Ford Superduty Diesel 4x4 110K miles
__________________
'02 F-250 PSD, 4x4, CC, AIS Intake, Magnaflow 4" Turbo back Stainless Exhaust, Isspro Pre-Turbo Pyro and Boost - Pillar Pod, Diablo 40 HP Tune
'98 Expedition - 5.4L
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-12-2008, 02:49 PM
ynevada is starting off with a positive reputation.
abs engaging?
so its pulsing the brakes?
thats in NO way going to CAUSE an accident.
have you checked the lines? maybe one is getting pinched?
have your wife(or anyone) start it, and while PARKED with the e-brake on turn the wheel all the way each direction. while u are down watching all the lines, and hoses.
__________________
reaperoffroad
  #3 (permalink)
Old 05-16-2008, 01:33 AM
bustech81 is starting off with a positive reputation.
How are the front tires wearing? could it be that the camber roll is so steep that wheel speed between both front tires changes enough to put it into an abs condition.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
