Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Escape and Escape Hybrid
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-07-2008, 06:51 AM
Avanti is starting off with a positive reputation.
08 Hybrid oil filter
How do you remove the oil filter? Changed a lot of oil filters but not sure on this one. Do you drain it 7 than twist it of by hand or tool?
  #2 (permalink)
Old 05-07-2008, 04:52 PM
gjrock is starting off with a positive reputation.
It is a cartrage type paper filter.need filter tool to get off.Oil and filter change due every 10k.It will drain down.Check your a/c filter every 15k.It is in the back on the d side.remove little panel and check it out.Keeps the batteries cool.
  #3 (permalink)
Old 05-07-2008, 10:04 PM
MazdaRangerGuyInSTL is starting off with a positive reputation.
gjrock is correct.. you simply unscrew the assembly, then remove the paper cartridge.. install the new (along with new o-rings) and screw the assembly back into place. There is a drain plug at the bottom of the assembly you can remove to drain it (to make it less messy), but this isn't necessary.
There are special sockets you can purchase for this (if you plan on changing your own oil regularly you might want to invest in this), and I highly recommend using this being it's a plastic housing, but I've had luck in the past using a large pair of channel-locks.
But like I said.. it IS plastic and breaks quite easily, so if you do try channel-locks be very, very, VERY careful. Also on reinstallation, it doesn't have to be torqued super tight.. just tighten it by hand and give it another quick 'nudge' with the tool.
  #4 (permalink)
Old 05-08-2008, 01:30 PM
Nitramjr has a great reputation on FTE.Nitramjr has a great reputation on FTE.Nitramjr has a great reputation on FTE.Nitramjr has a great reputation on FTE.Nitramjr has a great reputation on FTE.
That filter housing CAN be removed by hand if you really put some arm into it. I've never used a filter wrench on it because none of mine fit the housing.
The a/c filter is supposed to be checked at 10k and changed no more than every 20k. At least on the '05 and '06 models.
__________________
'97 F250 XL, 5.8L, '05 Escape Hybrid, '06 Escape Hybrid
Quote:
Are you schizo or do you just post that way?
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
