Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-06-2008, 10:46 PM
77 Bronco is starting off with a positive reputation.
A miss when idling and with throttle...
I hope this is in the right section. I have a 1968 Ford F-100, Automatic, manual brakes, 360FE 2 barrel completely stock w/ 70,000 miles. The truck started missing today. If you let the truck idle and stand at the back of the truck it will miss now and then. If I take off the vaccum line going to the advance module on the distributer and plug it then it will run smooth. The module does hold vaccume so I know the diaphram is good. The linkage also moves when I put a vaccum pump to it. I thought it was the points and condenser...changed them...re-timed...reset fuel rich/lean...ran like the day she came off the dealer lot. Went right back to having a miss. I checked all the distributer/points connections. Isn't there supposed to be a resistor for the coil? I threw another coil I had off something else to make sure the one that was on it wasn't bad. No change so I changed it back. My specs that I got were:
Plug gap: .035
Point Gap: .017 (good stating point really)
Dwell: 26-31 sitting at 29 but point gap isn't .017 anymore to acheive that
Point Resistance is a little high - not sure exactly how to remedy this
Idle RPM: 550-600 ....is just under 600 when in drive..800 when in park
Timing: 6 degrees BTDC
I have a set of autolite plugs in there now....only because these parts stores around here don't have the plugs for these old trucks laying on the shelves. Got a set of mortorcraft on order...should be here soon. Plugs look kinda light colored...maybe white...which means lean...I am 3-3 1/2 turns out on my mixture screws for the 2 barrel. It runs off choke..no issues there. My vaccum gauge is broke so I can't determine what vaccum I have. I've ran 3-4 tanks of good fuel throught the tank by now....no I don't beleive it is bad fuel. I add a lead additive so as not to hurt the valve seats. I am a young guy in my mid 20's and tried to pickup as much as I could from my dad before he passed. I know better than to throw parts at it...most of the time it is something that can be tested or thought out...or even overlooked. Still learning. Any help is much appreciated. Sorry if I am all over the place with the info. Let me know what kind of information you need. Thanks everyone.
__________________
1968 Ford F-100 Custom Cab, 2WD, 8' Bed, 360 FE (5.9L)
3 Speed on the tree converted to 4 Spd Auto
Power Steering conversion
Bought 2/08 with 69,300 miles.
  #2 (permalink)
Old 05-06-2008, 11:09 PM
Redmanbob's Avatar
Humble servant of my Peni
Redmanbob is starting off with a positive reputation.
Considering that if the vac line going to the carb is connected to ported it shouldn't have any vacuum at idle. Stumps me as to what effect the line being removed and capped could possibly have on the idle. If it's connected to ported vacuum and you have a vacuum at idle, something needs adjustment to correct this. As to it being part of the miss issue ?? Not sure but don't think it would be. Checked the plugs for cracks ? dizzy cap ? /carbon tracking.. Sorry not much help, "electrical is the devil" for this one... Born oblivious and seems it's gonna stay that way.
__________________
66 F100 352 V8
"Po-Dunk Redkneck Transplant"
CRATE = Cant Really Appreciate The Engine..
http://www.ford-trucks.com/forums/619321-russ-east-vs-west-3.html
  #3 (permalink)
Old 05-06-2008, 11:13 PM
My dizzy is a dual vaccum. The port towards the front is for manifold vaccume....off of the vaccum tee at the rear passenger of the manifold and the port closest to the body of the dizzy is vaccum from the carb...front passenger side port. Dizzy cap and rotor are worn but look good. But I was thinking of replacing anyways....but I don't see it being a problem since my issue is intermitent in a way. Thanks.
__________________
  #4 (permalink)
Old 05-06-2008, 11:18 PM
Oh, just so everyone knows....it misses on both sides of the engine. It has true dual exaust so u can hear it miss on both sides...has to be ignition. Oh, and the autolites are brand new...but I guess I could have a bad one or 2....hmmm...changing to motorcraft anyways
__________________
  #5 (permalink)
Old 05-06-2008, 11:33 PM
Bear 45/70's Avatar
Bear 45/70 is gaining momentum as a positive member of FTE.Bear 45/70 is gaining momentum as a positive member of FTE.
Plug wires. I also think you have you dual vacuum plumbed backwards.
__________________
Bear 45/70
Gimp Racing
Don't pick a fight with an old man. If he is too old to fight he will just kill you.
  #6 (permalink)
Old 05-06-2008, 11:38 PM
Plug wires are new....but I'm going to check the firing order tomorrow just to play it safe....still doesn't explain the miss here and there. Seems right to me...hoses are formed and almost fit right into place. Any info on how a dual vaccum is plumbed?
__________________
  #7 (permalink)
Old 05-07-2008, 07:59 AM
HOTWRENCH is starting off with a positive reputation.
Talking Miss
Manifold vacuum to the distributor will cause too much advance at idle and cause the symtoms you describe. Your vacuum advance is giving you too much total advance when idleing. Change to a single port vacuum advance and run it with ported vacuum and your problem will go away.
Have a good day-----Hotwrench
__________________
FERGUSON'S GARAGE est. 1967
car , truck , heavy equiptment repairs
4 X 4 specialists PORTABLE WELDING SERVICE
TOWING New @ used PARTS
1981 L 800 460 5 speed , 2 speed rear
1957 F 600 390 5 speed
  #8 (permalink)
Old 05-07-2008, 11:26 AM
Hotwrench....the dual vacuum distributer thas installed now is the original. I'd like to stay with that. Are these know for having issues? Newbie question...what is the difference between Manifold Vacuum and Ported Vacuum? I know Manifold is constant and vacuum from the carb is only there off of idle. I guess I am not familar with the term "Ported Vacuum". Thanks.
__________________
  #9 (permalink)
Old 05-07-2008, 04:01 PM
Talking Vacuum Advance
77 as far as the dual port vacuum advance goes , it was used for emission control. Just use the port on the front of the canister, not the one closest to the distributer cap. Ported vacuum is a part time source , the only time vacuum is present is when the throttle is opened. This port is on the carb body on Motorcraft carbs. Passenger side near the choke assembly. Some engines will tolerate full time vacuum advance , butt!!! many won't. That port on the back side of the dual advance canister is to retard timing , as stated it was used in emission control setups.
Have A Good Day-----Hotwrench
__________________
  #10 (permalink)
Old 05-07-2008, 06:01 PM
montana_highboy's Avatar
montana_highboy is starting off with a positive reputation.
Have you checked for vacuum leaks? if the miss is only during idle and part throttle i'd suspect a vacuum leak.
__________________
1975 Ford F250 4x4 Highboy 390 FE, NP435, NP205, HD44/D60, 4.11's, 235/85/16 BFG's
  #11 (permalink)
Old 05-07-2008, 07:43 PM
montana_highboy....I don't think it is a vacuum leak since when I pull the manifold vacuum hose off of the dizzy and plug it the engine smooths right out.
__________________
  #12 (permalink)
Old 05-07-2008, 08:29 PM
Bear 45/70's Avatar
Quote:
Yep, you have the manifold vacuum to the wrong port on the vacuum advance unit.
__________________
Bear 45/70
Gimp Racing
  #13 (permalink)
Old 05-08-2008, 10:53 AM
Bear 45/70...so I am assuming that the "Manifold" vacuum line goes to the closest port to the distributer cap and the "ported" or vacuum line coming from the carb goes to the port fathest away from the distributer cap....closest to the radiator? If I remember correctly i thought they may have been backwards...so I connected the "maifold" vacuum to the closest port to the cap and the truck died but I didn't have the "ported" or carb vacuum line on the other fitting closest to the radiator. I will give it a try again. Maybe I should post a picture in my gallery of how I have it set up. I'll try and do that tonight if I can. Thanks.
__________________
  #14 (permalink)
Old 05-08-2008, 11:27 AM
Bear 45/70's Avatar
Like was said before, the engine will run better if you just drop the manifold vacuum line altogether. It's there to please the government emissions BS and is not preformance enhancement. The reason the motoried is that the manifold vacuum retarded the timing causing the engine to die (it won't run that slow) You need to recheck you initial timing again too.
__________________
Bear 45/70
Gimp Racing
  #15 (permalink)
Old 05-08-2008, 11:45 AM
Bear 45/70 I beleive the vacuum is there for the advance to work. I don't want to go away from original. So something is either broken or not properly tuned or whatnot. Just trying to narrow it down. From whats been said here if I just do away with it I should be in the clear and I understand that. As I have said before. I am looking to stay original with everything working within reason. It's not my daily driver but I do try and take it out as much as I can. Real nice truck. I appreciate everyones input...just keep straying away from the issue of what is bad. In my mind....if it's original and worked foer some time and has gone bad or out of spec or whatnot...unplugging or disconnecting doesn't solve the issue in my mind. Could you imagine a doctor saying....sir..ur heart isn't functioning properly...we're going to disconnect it....lol Hope I don't come off the wrong way....I do appreciate everyones input. Just looking for a reason as to why I all of a sudden would have to disconnect it when it's been there it's whole life. I'd either like to replace/readjust/rebuild whatever is failing. But I am not looking to just throw parts at it. Thanks.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
