Quote:
Originally Posted by ReAX
I can't see your picture for some reason, why can't you cut a hole in your floor pan for the shifter to come up through or is it a cable type linkage transmission?
My 4sp trucks had a plate that bolted in the middle of the floor for the shifter to come through.
Yes I do not know why it will not enlarge! any how it is Fords trans made by Mitsubishi, the top of the trans sits above the floor just like the old low hole four speed, the floor pan was designed to cover the hump of the trans. it is the same cover that fits the one ton and the 21/2 ton. it bolts down just like the one you had.
