05-10-2008, 04:52 PM
Some stuff I forgot to mention-
Duals and single can flow the same. One is not better than the other, all things being equal. The only real difference is that duals are more expensive since you need to buy twice the pipe, and 2 mufflers. And of course duals are heavier too. The advantage is usually a sound that a single setup cant match. Dont let anyone tell you that one will make more power or torque than the other.
IMO, what you have is fine but you could probably make good use of a single pipe thats one size bigger than stock. Especially if you plan on any more mods in the future. Just get another Magnaflow muffler thats one size bigger and if you want the dual look just split it after the muffler. Can be done pretty cheap. Make sure the pipe is mandrel bent or you are masting your time.
__________________
1964 F100- Gonna see boost
1998.5 Ford Contour- Many mods
JOIN THE NEW MEXICO CHAPTER HERE
