Maybe its got Chebby syndrome every chebby I have had took 2 key turns, except it was everytime pretty much starting it but not every 8 like in your predicament.
I am assuming this happens every 2-3 days? The thing that comes to mind for me is maybe an emissions system problem or loose/faulty connection some odd place. See if any codes are tripped.
__________________
Gearhead for life slammin' iron & chrome right to the bone!
1992 F150 300-6ci
1976 Cadillac Coupe Deville 500ci
1998 Dodge Ram 4x4 318ci
1970 Chevy Nova SS 360ci
UPDATE:
After driving the truck for a week after replacing the PCV, truck has yet to stall on start-up.
If your Inline 6 is experiencing poor gas mileage, replace that PCV pronto! It will help.
Adipose
IAC valve is a known problematic piece of the EFI system on ford vehicles, it looks similar to a little electric motor attached near the throttle body with 2 small bolts and one connector. Pull it off, clean the unit itself with some carb cleaner or something. Also clean the orifice in the intake real good that the valve bolts into. The orifice can become very resrticted with carbon and oil deposits causing a rough or no idle situation. In most cases this is the problem. You can also replace the gasket between the TB and intake. The factory one is real weak and breaks apart internally causing a vacuum leak. Basically if your gasket isn't sticking out between the TB and intake, it has been partially sucked into the area between the TB and intake.
UPDATE:
Found the green wire from EGR valve disconnected. Broken 90 degree angle vacuum hose fitting. Must have been broken by past mechanic or previous owner. Anyhow the truck is running allot nicer now. It accelerates allot smoother and runs better in general.
Since connecting it, the truck has not yet stalled on the first cold start up of the day, but has come very close to stalling, catches and continues warm up sequence (hi RPM to lower RPM etc...)
Wondering if that IAC valve still needs a cleaning that Heavy_Metal brought up.
All in all pretty happy about that EGR fix so far.
Hope MPG's increase from the 14.5 mpg's (town and freeway) work commute.
