Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Escape and Escape Hybrid
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-06-2008, 03:42 AM
DealsDice2 is starting off with a positive reputation.
trouble code 0705
I have a 2004 Escape with 116K miles. Over the weekend I started having a shifting problem. When I put the vehicle into Drive, the engine revs and will creep forward with no real power. If I drop it down to 1 or 2, it will slowly drop into gear and I can then accelerate and then switch to Drive. I checked the fluid and it was low. I added and the stick shows good now, but did not fix the problem. The check engine light has NOT come on.
I put the odometer into test mode and come up with a dtc code of 0705. Research shows that is a "Transmission Range Sensor" code. I plan to take the truck over to the local auto parts store to have them hook it up and see what codes they come up with.
I've looked online and do not see a replacement part for "transmission range sensor", but I do see a "transmission speed sensor". I assume these are relatively easy to replace. Obviously I am trying not to take it into a shop without troubleshooting first.
I'm not sure if this is related, but after adding trans fluid, suddenly the headlights don't work. Parking lights, fog lights, and high beams work fine. My searches on that problem come up with either that simply both bulbs burned out at the same time or possibly that a bad taillight bulb causes the headlights to cut out.
I appreciate any help or insight that anyone can offer.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
