Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-05-2008, 11:24 PM
bigfoot22's Avatar
bigfoot22 is starting off with a positive reputation.
1974 360
Ok guys,I'm fixing to ask some dumb questions on here so please bear with me. I have an 1974 F-100,just rebuilt 360 (.030 over). 2 bbl carb.2wd.SB. 350 gears in the rear.
1-What the heck does FE stand for?
2-I'm wanting to go back and replace the stock intake with an edelbrock performer and a 600 cfm carb.headers(best brand?) install new dual lines with flowmasters.Is this a good set up?
3-I have been told you get better gas milagg with a 4 bbl. carb and headers if you stay out of the throtle to much.Is this true?
4- Thanks for all your help and sorry for such a long post.-Ken
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-05-2008, 11:36 PM
bigfoot22's Avatar
Sorry, I forgot to add it has an auto trans.
  #3 (permalink)
Old 05-05-2008, 11:44 PM
66f25red is starting off with a positive reputation.
Bigfoot, I had a 352 that was bored, a 390 crank, high comp pistons, new bronze guieds, an Elderbrock intake with a 4bbl, mucho power, 16 mpg on hwy. 2700 rpm. True duals with glass packs. mmmmm good.
__________________
66 F250 with utility body, very rusty oxidized red painted over PG&E colors. Ugh? A real restorers dream
90 F250 HD 4x4 - gone to a better place
67F250 4x2, 352 w/ 390 crank and RV cam, NP 435, 4 tube radiator, dual exhaust. Sob! sold it.
  #4 (permalink)
Old 05-06-2008, 12:26 AM
Tony238 is starting off with a positive reputation.
1. FE stands for Ford Edsel or Ford Engine depending on who you ask, but I think it is generally agreed as Ford Edsel.
2. Any FE benefits from headers. The performer is really no better than a cast iron intake maniflod except for weight, so spring for the RPM.
3 You can get better milage with a 4 barrel because it has smaller primaries than a 2 barrel.
  #5 (permalink)
Old 05-06-2008, 12:34 AM
85e150six4mtod has a good reputation on FTE.85e150six4mtod has a good reputation on FTE.85e150six4mtod has a good reputation on FTE.
What compression ratio did you build back into that thing...?
  #6 (permalink)
Old 05-06-2008, 01:12 AM
Bear 45/70's Avatar
Bear 45/70 is gaining momentum as a positive member of FTE.Bear 45/70 is gaining momentum as a positive member of FTE.
1)Here's what Ford says in their Muscle Parts Book.
2)Unless you really have a big need the aluminum intake and stock Ford iron intake will give better bottom end preformance and probably better mileage too. Look for an "S" intake. A 600 will work fine.
3)The answer is yes.
4)You are welcome.
__________________
Bear 45/70
Gimp Racing
  #7 (permalink)
Old 05-06-2008, 06:46 AM
NumberDummy's Avatar
Ford Parts Guru
NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.
FE engines introduced in 1958.
Ford Fairlanes & Customs could be ordered with either a 332 or a 352 / Edsel offered a 361.
The Edsel's 361 engine was only used in 1958. This FE engine is not related to the 361 FT engine used in 1964/78 F600 and larger trucks.
__________________
Bill / Retired Ford Parts Manager ~ 1962/1997
Part Number Research: Trucks: 1928/2002 / Cars: 1928/2003
1963 Galaxie 500XL / 1965 F100 / 2008 Fusion S / 2008 Edge SEL
  #8 (permalink)
Old 05-07-2008, 09:14 PM
bigfoot22's Avatar
I want to say the compression is 9.5 to 1
  #9 (permalink)
Old 05-08-2008, 01:48 AM
Do the headers with duals and a crossover pipe first. See how you like it.
It is true you CAN get more MPG with a 4bbl, but odds are you won't. If you are going to balloon foot the loud pedal to stay out of the secondaries, why have a 4bbl? Once you hear the atmosphere collapsing into that thing, you'll want to hear it again and again...
What size tire you running? You might be able to change to a 3.00 gear too.
  #10 (permalink)
Old 05-08-2008, 07:57 PM
bigfoot22's Avatar
Hey 85e150,another dumb ?-what is a crossover pipe.Tire size is p235 70R 15
  #11 (permalink)
Old 05-08-2008, 08:00 PM
bigfoot22's Avatar
are you saying run the headers and duals and keep the 2 barrel and stock intake.Man you're saving me some money here.I did'nt know what the stock set up would sound like with the headers and duals alone.Thanks
  #12 (permalink)
Old 05-08-2008, 08:46 PM
Bear 45/70's Avatar
Quote:
It will sound the same as it would with a 4 barrel.
__________________
Bear 45/70
Gimp Racing
  #13 (permalink)
Old 05-09-2008, 12:12 AM
bigfoot22's Avatar
thanks guys.Looking for an exhaust shop that will install the headers and dual lines.Talked to one guy today.He did'nt want to mess with the headers,just the lines and mufflers.I'm going to call around on friday see what i can come up with.
  #14 (permalink)
Old 05-09-2008, 12:36 AM
Ford used a tube to connect the dual exhaust. Mellows out the tone, gives another path for each exhaust pulse, supposed to help torque. I changed to one on my Mustang and the difference in sound was noticable.
With those tires at 28 inches and the 3.50, you should be turning approx 2730 rpm at 65. Change to a 3.0 and you are turning 2340.
mph 3.50 3.0
70 2940 2520
65 2730 2340
60 2520 2160
55 2310 1980
Your engine should pull those revs ok with light to medium loads, but if you are towing or hauling heavy loads, you should probably stay with the 3.50s.
Our '66 Country Squire was close to 4000lbs with a 390 2v, C6 and 3.0 and similar sized tires. It was tolerable off the line.
  #15 (permalink)
Old 05-09-2008, 10:04 AM
bigfoot22's Avatar
Any concerns that I should be aware of on installing headers?(brackets,belts,starter)Thanks again.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
