Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford Inline Six, 200, 250, 4.9L / 300
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-05-2008, 09:26 PM
jefxxo is starting off with a positive reputation.
How often do you replace yours?
Well I'm losing gas millage, and I guess its time to do a tune up anyway. Im going to do Plugs, cap, rotor, PCV valve. (wires are still good) But my question is How often do you replace your "Oxygen sensor" they say every 30,000 miles. But I have about 220,000 and never changed it. Would it be safe to say i need to change it?
Im getting a slight miss both at idle and when im on the highway
Also what about the EGR stuff. Would any of that be in need of repair. Or should that just last?
Other than that truck runs great. No different than from when i got it at 100,000 miles.
  #2 (permalink)
Old 05-05-2008, 11:16 PM
fmc400's Avatar
fmc400 has a good reputation on FTE.fmc400 has a good reputation on FTE.
Well, since 220,000 >>> 30,000 I would say it's time Careful with that thing though; douse it with some PB Blaster. That thing will be stuck in there.
Before you tear into the EGR, do the tune-up that you were going to do anyway. Maybe that will get rid of the miss. That will let you diagnose things with a "clean slate." Check the resistance of your plug wires since you won't be replacing them. They should not exceed 5 Kohms per foot.
  #3 (permalink)
Old 05-05-2008, 11:24 PM
Sounds like a plan. Is there any tricks to the EGR Replacment, or testing?
  #4 (permalink)
Old 05-05-2008, 11:40 PM
Corner Gas's Avatar
Corner Gas is starting off with a positive reputation.
To test the egr reach behind it and squeeze it and if the diaphram moves and springs back it is still good.
__________________
Colin
2000 PSD F250XLT Ext cab, SB, 4X2, Zoodad, ccv, Kwik filter W/Pete's cover , 4" turbo back flo-pro ss exhaust, fog lights & box cover
1967 Mercury F500 330, 2 spd axle 8 x 12 box & hoist
1978 F100 Custom 300 I6 (fresh), 4spd std (rebuilt) new hubcaps.
Life is to short to drive an ugly truck
  #5 (permalink)
Old 05-16-2008, 09:21 PM
stresssolutions is starting off with a positive reputation.
My plug wires were original-------->1994. Just changed them, but they didn't have a cap/rotor. Also couldn't get plug #2 out.
__________________
94 F150, 115k 4.9l 5sp.
88 Accord LX 182k
04 Hyundai XG350L 46k
  #6 (permalink)
Old 05-17-2008, 11:15 AM
OldMetal's Avatar
OldMetal is starting off with a positive reputation.
Use some ant-sieze on the plug threads when you replace them.
__________________
77 F150 4X4
  #7 (permalink)
Old 05-17-2008, 11:46 AM
Eddiec1564 is starting off with a positive reputation.
To check the EGR valve is leaking or stuck, idle the engine and press on the diaphram like Corner Gas said, usually the engine will start to run badly(may even stall out) the more you press on the diaphram, relese it and the enging should idle back normaly. If no change, then the valve is stuck or burnt, or the passage ways are plugged with carbon. A old trick showed to me, that works really good for EGR problems.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
