05-05-2008, 11:58 PM
I would not assume it's ground. The only way to know what it's for is to take an ohmmeter and see what it has continuity with. If you touch one lead to the mystery terminal, and the other lead to the housing, and get continuity, then I will go along with the guy at the parts store.
If you do not get continuity there, then check all the other terminals, put the switch in another position, and check them again. Do this for each position till you figure it out. More than likely you will not need it, but then again if you find out it's function, it may be useful to you to hook something up.
__________________
Dave F
1989 F250 XLT Diesel
