Jose look at the lower right corner of each post. Right next to the quote button is a button with " and a plus sign. If you want to quote three post then in the first two hit that button and on the third hit the regular quote button. then you can reply to each.
Thanks TJ, I made it, I made it, he he he. every day you learn something !!
Originally Posted by tjbeggs
Nice post!! Tried to rep you but you know the story!!
REP SYSTEM
No problem I know that. thanks any way.
Originally Posted by RubberDuck
I tried to rep you as well Jose, no dice.
Also thank to you RubberDuck, somebody should change that system.
i ordered the part from powerstrokeshop.com. those are 3" outlets on there right? thats why we need the step down connections if i am understanding this right. the thought crossed my mind to get the aluminum intakes from beans or find a donner SD 7.3 to get the intakes from. im curious to how bennificial it would be
Yes thats the reason to step down connections.
Originally Posted by sticks25
nevermind, i should have done more reading before i asked. i found my answers! ill learn sometime
