Go Back   Ford Truck Enthusiasts Forums > General > Ford vs The Competition
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Ford vs The Competition Technical discussion and comparison ONLY. Trolls will not be tolerated.
  #1 (permalink)
Old 05-05-2008, 05:14 PM
builtfordtough13's Avatar
builtfordtough13 builtfordtough13 is offline
1978 Ford F-150
My Garage
builtfordtough13 is gaining momentum as a positive member of FTE.
GM releases details on upcoming Duramax 4.5L diesel
310 hp and 510 ft lbs. what was the expected hp and ft lbs. of the 4.4L from Ford.
__________________
Jake
DD:1994 F-150 4x4 Supercab, 351, E4OD,187k Rough Country Leveling Kit and 9000 Series Shocks
Project:1978 F-150 Reg. Cab 4x2 302 c4 Edelbrock Carb, Cam and Intake, TCI Shift Kit, 3.70 Gears
  #2 (permalink)
Old 05-05-2008, 05:32 PM
dkf's Avatar
dkf dkf is offline
Garage is empty, add now
dkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to behold
I don't think Ford has released final hp & tq numbers yet and I highly doubt Ford even knows as of now what the final numbers will be. I honestly wouldn't touch one of the 4.4l or 6.7l diesels that are coming out in 2010 at least until 2 years after they are released. Fords building these engines in their new plant and there are new emmision standards for 2010. I'll keep my truck. Those are impressive numbers though from the Chevy 4.5l diesel.
  #3 (permalink)
Old 05-05-2008, 07:30 PM
BigF350 BigF350 is offline
2000 Ford F-350
My Garage
BigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputation
adrian.erks.harris adrianerksharris
http://www.ford-trucks.com/forums/73...ng-a-look.html
__________________
Adrian | 2005 4x4 Diesel Ranger CrewCab in Aus | 2000 4x4 SC/LB F350 7.3 ZF-6 in the US
  #4 (permalink)
Old 05-05-2008, 10:49 PM
BigDaddy6969 BigDaddy6969 is offline
BigDaddy6969 is starting off with a positive reputation.
Wow, GM isnt screwing around, those are some awesome specs.
__________________
2012 Ford F350, 6.2, Auto, 4X4, Crew Cab, SRW, Short Box
2008 Dodge 3500, CTD, Auto, 4X4, 4 door dually
1999 Dodge 2500, 8.0 V10, 5 Speed Manual, 4X4, quadcab, longbox
  #5 (permalink)
Old 05-13-2008, 07:22 PM
themoparkid's Avatar
themoparkid themoparkid is offline
themoparkid is new and has a neutral reputation at this point.
I dont get why Ford and Chevy is going down in size of liters on there diesels and Dodge keeps bumping the size of there diesels.
  #6 (permalink)
Old 05-13-2008, 08:00 PM
2000 Ford F-350
My Garage
These are diesels for the 1/2 tons
__________________
  #7 (permalink)
Old 05-14-2008, 01:50 AM
kermmydog's Avatar
kermmydog kermmydog is offline
ARIZONA CHAPTER
1995 Ford F-150
kermmydog has much to be proud ofkermmydog has much to be proud ofkermmydog has much to be proud ofkermmydog has much to be proud ofkermmydog has much to be proud ofkermmydog has much to be proud ofkermmydog has much to be proud ofkermmydog has much to be proud ofkermmydog has much to be proud of
4.4 Ford diesel 9% more HP & 15 % more torque than a 5.4 gas? I don't think that compares even close to the Chevy 4.5 diesel spec does it?
  #8 (permalink)
Old 05-14-2008, 07:21 AM
dkf's Avatar
dkf dkf is offline
Ford better match or get friggin close to the Chevy power wise.........if they don't they might as well not even bother.
  #9 (permalink)
Old 05-14-2008, 05:15 PM
1978 Ford F-150
My Garage
We have no clue, because we don't know how much the next 5.4L will be making, so I assume it will be really close with more horsepower.
__________________
Jake
  #10 (permalink)
Old 05-22-2008, 09:28 AM
excaliber551 excaliber551 is offline
excaliber551 is starting off with a positive reputation.
Quote:
I doubt they'll even try. Look at the 5.4. They've been building it for years and it's still the most underpowered poor performing engine in it's class.
Ford must have a bunch of idiots designing their engines.
  #11 (permalink)
Old 05-22-2008, 01:02 PM
Quote:
Damn straight, glad to see i am not the only one that thinks this way.
__________________
  #12 (permalink)
Old 05-22-2008, 01:21 PM
cleatus12r cleatus12r is offline
cleatus12r has much to be proud ofcleatus12r has much to be proud ofcleatus12r has much to be proud ofcleatus12r has much to be proud ofcleatus12r has much to be proud ofcleatus12r has much to be proud ofcleatus12r has much to be proud ofcleatus12r has much to be proud ofcleatus12r has much to be proud of
Quote:
Can somebody PLEASE tell me WHY the GM thinks that we need 1/2 ton trucks that have more HP and torque than the original Duramax LB7?
Sure, it still has the same semi-floating rear axles as every half ton out there but it's got enough torque to haul 6000 lb. in the bed and 20K lbs. on a trailer....."properly equipped" of course.
__________________
2000 F250 PSD Regular Cab 2wd with an automatic. One hundred percent stock except for having 250/200% injectors running at stock power output.
1995 F250 PSD SuperCab longbox 4wd with an automatic. Also all-stock.
  #13 (permalink)
Old 05-22-2008, 06:31 PM
duramaximizer duramaximizer is offline
duramaximizer is new and has a neutral reputation at this point.
Aleast it will have enough hp to pull 10,500 pounds up a hill decent. Hopefully it will have 2 modes, an economy, and a tow/performance mode. That would be awesome.
  #14 (permalink)
Old 05-22-2008, 08:09 PM
92f150I6's Avatar
92f150I6 92f150I6 is offline
2003 Ford F-250
92f150I6 is gaining momentum as a positive member of FTE.
Quote:
I can see those cute little rear ends blowing apart for sure. Though the power is nice, it is totally unnecessary for a half ton. I also hop they strengthen that fram, because it's going to need it.
__________________
2003 F250 SD 4X4 5.4L 4:10 Arizona Beige
1987 Mustang GT
09 Challenger RT
A bunch of motorcycles, other cars, and a Quad.
  #15 (permalink)
Old 05-23-2008, 01:44 PM
DMAX-HD's Avatar
DMAX-HD DMAX-HD is offline
DMAX-HD is starting off with a positive reputation.
I think a power loaded diesel in a 1/2 ton will be the best thing sinced slice bread. Do guys know how many people had to jump up to a 3/4 ton just to pull their camper safely a couple times a year? And why wouldn't you want 25% better mileage? I wouldn't worry to much about the powertrain - GM has been ahead in the that dept. since the inception of the D/A combo.
__________________
2008 LMM Duramax - Crew cab LT Z71 3/4 ton
EDGE CTS Race Tuner
MBRP turbo back DPF delete exhaust
18x9 KMC XD Hoss Wheels -
Rare Parts HD tie-rods
Cognito pitman/idler arm braces
Tags
35, 44l, 45, 45l, diesel, duramax, ford, lt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
