Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Clutch,Transmission, Differential, Axle and Transfer Case
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-05-2008, 04:14 PM
aeomholt is starting off with a positive reputation.
E4OD - Errorcode 1, 23 and 29
Hi, my -92 E350 7.3 E4OD have a flashing od-ligt and I'm getting errorcode 1, 23 and 29. Check engine lamp flashes in this order: 1 (weak/very short), 23, 23, 1, 29 29.
What does these codes mean?
The trans misses gears, hard shifts, can't decide which gear to chose, "hard" downshift while stopping. TPS/FIPL reads 0.98V and goes smothy up to 3.8V and TPS/FIPL are the "bad black one".
Anyone who can list/link to all the different errorcodes which the trans can set? I cant find a list anywhere...
Thanks!
__________________
1992 Ford Econoline E350 7.3 IDI 120 000 miles
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-05-2008, 06:16 PM
projectSHO89 is gaining momentum as a positive member of FTE.projectSHO89 is gaining momentum as a positive member of FTE.
"1" is not a fault code, it is a separator between the EO/ER and the continuous memory codes.
23 = a problem with the TPS or the throttle mechanicals
29 = PSOM output signal problem
Does your RABS work correctly? The PSOM uses the rear differential RABS sensor as its input. A bad sensor will screw up the whole shifting strategy and the PCM won't know when to shift properly.
Sounds like other vehicles that have a bad VSS sensor...
Steve
__________________
Think about it: Ignorance can be addressed through education but you can't fix stupid! ...apologies to Ron White
  #3 (permalink)
Old 05-05-2008, 07:05 PM
Steve
I do not know if the RABS are working propperly or not but I will have to find a wet slippery place to test it. Since the TPS/FIPL are the old black one I think will change it any way.
Where did you find these codes?
__________________
  #4 (permalink)
Old 05-07-2008, 03:18 PM
I have just tried another instrument and the transmission shifts like it should.
Then I guess it was the PSOM which was faulty. I forgot to test if the cruisecontrol started working again.
__________________
  #5 (permalink)
Old 05-07-2008, 05:13 PM
Since I'm in the electronics buisness I took the instrumentcluster apart and checked the PSOM PCB and it was full of bad solderpoints. I'm excited to try it tomorrow!
__________________
  #6 (permalink)
Old 05-09-2008, 09:25 AM
In the factory service manual (PCED).
Steve
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
