Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Escape and Escape Hybrid
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-05-2008, 03:11 PM
itswrongway is starting off with a positive reputation.
2001 spark plugs
how hard is it to change the plugs on the 3.0 v6 escape ? is it true that the plugs stripe out the threads in the head real easy ?
  #2 (permalink)
Old 05-05-2008, 07:53 PM
Pejeeper is starting off with a positive reputation.
There's a large thread dedicated to this topic, shouldn't be more than a page or two off the front page. I did an 01 a few months ago with no strippage of threads. Just take your time and if a plug feels stuck, don't force it.
  #3 (permalink)
Old 05-06-2008, 02:54 PM
tcesni is new and has a neutral reputation at this point.
There is an excellent thread with photos to show you exactly how to change the plugs. It takes 2-3 hours taking your time. If you have a wireless server in your house its great to have the laptop on a bench in the garage as you go along. Be sure to replace the gaskets between the upper and lower intake manifolds when you do it and if you have any plugs that give you trouble give 'em a blast of PB Blaster and let them soak for a bit. Its worth the time spent. I had no problems doing my '02 Tribute with over 100k miles on it.
  #4 (permalink)
Old 05-09-2008, 06:20 PM
2fords2 is starting off with a positive reputation.
This is one of the best "how to" threads for replacing spark plugs in an Escape ... complete with photo links.
http://www.ford-trucks.com/forums/45...ark-plugs.html
  #5 (permalink)
Old 05-10-2008, 08:02 PM
MazdaRangerGuyInSTL is starting off with a positive reputation.
Just a couple of tips:
1> When removing the plugs, loosen it about 1/4 to 1/2 of a turn... then spray some penetrating oil (such as WD40) in the plug hole... let it soak 5-10 minutes... then tighten the plug until it bottoms out, and then remove it. This will dissolve any carbon build up and lubricate the threads to minimize the risk of thread damage in the head.
2> When installing the new plugs, first add a little bit of anti-seize compound to the threads of the plug (be careful not to get it on the end of the plug itself), then install it in by hand all the way (you can use an extension and socket but turn it by hand). Once the new plugs are bottomed out, use the ratchet to torque them down. If they do not thread in easily by hand, thread the plug back out and try again.
3> When you start the vehicle, make sure you're in a ventilated area as the penetrating oil from step 1 will have entered the combustion chamber, and this tends to smoke for a minute or two.
Good luck!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
