Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-05-2008, 01:32 PM
fords and kenworths is starting off with a positive reputation.
next 460 build
working on my 3rd 460 build now, the first 2 were built for low end power, but this ones a little different. Im looking for power from like 2000 rpm and up. I have a 750 cfm edlebrock carburetor to use and was thinking of going with there 7166 manifold. The heads are stock with a port job, the block is .040 over with a stock style piston, and will be buttoning it together with main studs and girdle, and headstuds. The block has been shaved slightly, so Id assume the compression will go up a few points. Ill be running full msd ignition with there 6al box. So first question Is the rocker arm bolt on a small block and big block the same, because I have a set of pedastal mount rollers off a 302? should I run shorty headers or long tube headers? As far as a camshaft heres were im lost, I feel something around 220 on the duration for both sides and around 495-515 on the lift on both sides do you guys think thats about right? Should i go with a larger cam? also how long is a stock pushrod?
This is going to be a mud truck\pulling truck, Its going to live in low range by the way, but i want something I can really stretch out the rpms with. Im also running a 4speed with a 3.55 rear end and 33 or 35 inch tire. Block is a 71' and the heads are 73'. open for all suggestions.
Sponsored Links
To remove this ad, register today!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
