Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-05-2008, 01:32 AM
dgrant09 is starting off with a positive reputation.
390 Rebuild
Well our leaking head gasket (I hope that is what caused the water in the oil) lead to a compression check and that was in the dumps across the board. We will be rebuilding it with a stock kit. I saw a kit in a catalog in which the cam in the kit could be replaced for a RV cam for an additional $20.00. What would this do for overall mileage and performance?
Thanks
__________________
72' F250, Camper Special
2WD, 390
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-05-2008, 09:34 AM
Redmanbob's Avatar
Humble servant of my Peni
Redmanbob is gaining momentum as a positive member of FTE.
If it's the kit from fastengineparts the cam is just a step up from stock. It seems to make a nice difference in lower end on the 352 and has pretty good pull no matter what. So it would seem to make sense it will be fine in a 390.
__________________
66 F100 352 V8
"Po-Dunk Redkneck Transplant"
CRATE = Cant Really Appreciate The Engine..
http://www.ford-trucks.com/forums/619321-russ-east-vs-west-3.html
  #3 (permalink)
Old 05-06-2008, 11:15 PM
Quote:
I'll be able to finish the tear down this coming weekend and get into ordering parts. Will this reduce mileage? We'll check with our parts person and see if we'll be able to step up the cam with the engine kit.
__________________
2WD, 390
  #4 (permalink)
Old 05-12-2008, 10:34 AM
390428cjt's Avatar
390428cjt is starting off with a positive reputation.
comp cam 270H is a little better upgrade dont expect big milage gains with any FE motor just performance gains for the same gas useage
__________________
390428cjt
FORD IS THE MOUNTAIN THE ROCK FELL OFF OF
1972 F-250 Camper Special 396 C-6 Dana 60 4.10 lim.
1996 F-150 XLT 4X4 5.8 Heavy Duty Package
1982 escort 52k 2dr hatch
  #5 (permalink)
Old 05-12-2008, 10:50 AM
Thanks for the info!!
We did finish the tear down and only the intake gasket appeared to be leaking (3 ports) with small scaring on two crankshaft journals. Hope the block is not cracked, taking it all in for a hot wash and magna flux today.
One surprise was to find the block has been bored before, .30 over then so we'll go to .60.
A couple of the young shop folks (they help us dummies) were surprised at the wear on the piston and low compression # and the truck was still running (low was around 5 and a high of 30). I suppose that shows how tough these old engines are!
As mentioned above we will be going with the cam to help with the low end. With the compression # above, the rebuild alone will be a significant improvement in performance..
__________________
2WD, 390
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
