Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Appearance & Dress-Up
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-04-2008, 10:46 PM
deadscout is starting off with a positive reputation.
how to remove grill?
I am trying to remove the honeycomb grill from my 2000 SC. I was told that it had some tabs that hold it in place, but could be worked out the front by pulling on it. I took a small screw driver and pried around it while pulling, but it looked as though it would break before it came loose. Should I keep prying or is there another or better way to get it out?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-04-2008, 11:32 PM
dew the thunder's Avatar
dew the thunder is starting off with a positive reputation.
Are we talking about an F150 or a Super Duty?
__________________
-Brice-
1999 V10 F250 SD XLT 4X4 4.30LS
18X9 XD Badlands, 285/65 Nitto Dune Grapplers,
K&N, Chrome Grille, New headlights & corners, Bilsteins,
RECON: Clear Cab Lights, White Lightning LED bar, LED interior lights,
Putco LED 3rd brake light, FM 40, SuperWinch hubs, LED Tails
  #3 (permalink)
Old 05-05-2008, 06:08 AM
ReAX's Avatar
ReAX is gaining momentum as a positive member of FTE.
I had to grind off some plastic rivots on another kind of grille, and some of grille kits require cutting the shell up. For cut style billet, I like a roto-zip bit in a flex shaft drimel.
__________________
Too many mods to list, so click here.
-MECP 06/27/08
Look, see these two tow hooks? They look like tusks. And what kind of animal has tusks?
there's a very fine line between not listening, and not caring. I like to think that I walk that line every day of my life.
  #4 (permalink)
Old 05-06-2008, 07:56 AM
I'm talking about a regular f150 xlt with the oem grill.
  #5 (permalink)
Old 05-06-2008, 03:13 PM
Sorry man can't help ya...
__________________
-Brice-
  #6 (permalink)
Old 05-06-2008, 07:53 PM
superdutymj's Avatar
superdutymj is starting off with a positive reputation.
there are tabs but they require that the grille shell be removed. You'll have to bend the tabs on the grille until it lets loose from the shell. Those tabs will break pretty easy on the shell, so be cautious. I took some pliers and broke the tabs on the grille itself cuz I was just going to throw the grille away and didn't want to damage the shell.
__________________
-1998 F150 Lariat 4x4 SuperCab Short Bed 5.4L with 22x,xxx mi: 285/75R16 Nitto Terra Grappler True Dual Exhaust "SUPERFORD"
-1980 F350 Flatbed 4x2 4spd 460 DRW "Ol' SMOKY"
  #7 (permalink)
Old 05-07-2008, 12:56 PM
Thanks superdutymj, that was what I was beginning to suspect, but wanted confirmation before I took the thing apart.
  #8 (permalink)
Old 05-27-2008, 01:44 AM
lascrew's Avatar
lascrew is starting off with a positive reputation.
Use can use this info. The removal instructions still applies no matter what type of grille you are installing.
>>>>>>>Grille Installation.
  #9 (permalink)
Old 05-27-2008, 06:06 AM
most quality grilles use the tabs to mount the billet grille, the instructions you gave were for a stull (low quality) billet grille and the tabs in the instructions were cut off. I've got a precision billet grille and I had to use the tabs to mount the grille, and it looks alot better than the other ones that require cutting up the factory grille shell.
__________________
  #10 (permalink)
Old 05-27-2008, 01:46 PM
lascrew's Avatar
Quote:
To each their own, and everyone has their own opinion, but tab removal does not necessarily correlate with inferior quality of the subsequent grille being installed.
However, the purpose of my post was not to refer "exact" instructions for installing a Stull grille but give instructions of the process of getting to the point of installing "any" grille; regardless if it requires the removal of the tabs or not.
This is why my post states "The removal instructions."
I would gather most folks would understand that. I found this as helpful instructions when I had to remove my stock grille to install my "non-Stull" grille; and there are not too many references like this online.
Deadscout,
Here is another online instruction post showing removal. >>>> Grillcraft Install
  #11 (permalink)
Old 05-27-2008, 06:53 PM
no doubt, but all grilles are different, and the majority of the instructions you listed were to cut the tabs off the grille shell.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
