per the ford 2001 7.3 diesel supplement the max GCWR for towing a fifth wheel with your truck is 20,000 lbs. so you need to find out what your truck (loaded up) weighs than subtract that from 20,000 and that will give you the max fifth wheel weight the truck is rated to tow
