Major Oil Leak SOS HELP!
I just went outside to find a bunch of oil under my truck. I have a 2001 F-250 PSD. I have no idea what it could be or how to fix it. It seems to be coming from somewhere by the powersteering. It is leaking and dripping on my front axle and when I drove it earlier today before noticing it must have blew some back on the oil pan because there is some leaking there too. If some one could help me out I really would appreciate it, I am trying to avoid taking it in and paying big bucks if I can do it myself. If anyone could point me in the right direction I would appreciate it...
Thanks,
Derek
Hopefully the Pictures Help!
Thanks,
Derek
Pics were of little help. We need to find where it is coming from.
Case in point, I met MikeSDK in Nashville this past Thursday. I have had a pesky fuel leak since Smokin. He was checking out my truck and noted I might have an oil leak. It was leaking down onto the pavement. I said I was aware I had a leak and thought it was fuel. I had puddles in all 3 recesses of the engine valley. The fluid was black like oil.
The other day I got after it and sprayed it down with brake parts cleaner, sopped it up, then started the truck. Found it was leaking from the fitting at the return line from the fuel pressure regulator. I found the fitting had loosened. Tightened with a wrench and leak is fixed. Cost was 0.00.
So the point is, find the source, then fix it.
Get a good degreaser (lots here use simple green) and spray the problem areas down good and then wash them off with a garden hose. Put plastic bags around the alternator, PS pump and anything electrical.
lol..I caught this one too, but I didn't say anything I didn't want to give the poor guy a heart attack.
I believe the whole system holds 8 gals of 50/50 mix.but if you really want to do it and not have the hassle of using the anti-cavitation additive all the time.Maybe think about completely flushing the green stuff out and putting in some with the additive already in it.I haven't done it yet its on my to do list.but there is alot of threads about it you can do a search and get it easy.Also maybe a new billet stat housing while your at it.Its made better and doesn't normally leak like the OEM does,so they say.The antifreeze you want to use is this stuff;ROTELLA® ELC Extended Life Coolant/Anti-Freeze .But you must make sure you get every drop of old coolant out,they don't mix.Means you must flush a few times until clear water then drain and fill with distilled water and that stuff.
Here is a link for the billit housing
I went under the hood and noticed Oil Pressure Sending Units was wet with oil along with the connector when I pulled it out. I am wondering if this is my problem. Here are some picture if you guys can could you take a look and let me know... And is this called the oil pressure sending unit or what is it and if possible would you guys know the part number.
Are we talking about this?
That is your ICP. Usually when we talk about this leaking oil it's in conjunction with a no start situation or a poorly running truck. Many folks have found a good deal on ebay. Hopefully someone will come along with a link. If the ICP is leaking oil I'd replace it sooner rather than later.
