Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Aftermarket Products
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-04-2008, 02:57 PM
just-n-time's Avatar
just-n-time is starting off with a positive reputation.
Talking Tonneau cover
How do you order one and from who? what do you look for? what is good and not?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-04-2008, 08:06 PM
ReAX's Avatar
ReAX is gaining momentum as a positive member of FTE.
I used to go to trade/vendor shows and talk with the reps. Nothing beats hands on experience.
Brands I like are Extang,Truxedo, Pace Edwards, and Under Cover. Extang has a lot more adjustment than people think, the snaps are offset and slide so they can be flipped for more/less tension and ease of snapping the cover down, the bows are also adjustable, two positions. I stick with them for the Black Max, it's a basic snap down with no frills
and is comparably priced with more features than the competitors for that kind of cover.
Truxedo is the next better cover. I like their spring loaded pistons and latches better than the competition. Their velco is industrial grade and easily replaced, I did an upgrade once, but in 7 years never had a problem with it.
Pace Edwards is a great cover, I find their install is much easier than Roll-n-loc, but Roll-n-loc is a top quality cover too. I have the bed locker now, but I have also had the original roll up and Roll-n-loc's original.
Under cover is the only hard cover I would consider owning. Fiberglass covers usually have a piano hinge that makes you remove all of the frame to take it off, are in the 60lbs weight range, require waxing, and will eventually crack and scratch. I like Undercover's plastic cover better than the other, mostly for the engineering and looks. They put a lot of effort into some of the brackets and the cover lacks unnessisary shapes and bumps. The under side is reinforced, and I've seen pictures a rep had of a 400lb man jumping on one. It's a nice cover if you want a hard cover.
Nothing against the others, but my hands on has lead me to this list.
I've had to replace several sportsmaster rear bars and you must remove one of the rails to give them a serial number before they can help you. Other than them, I've don't have anything negative to say about the rest.
__________________
Too many mods to list, so click here.
-MECP 06/27/08
Look, see these two tow hooks? They look like tusks. And what kind of animal has tusks?
there's a very fine line between not listening, and not caring. I like to think that I walk that line every day of my life.
  #3 (permalink)
Old 05-04-2008, 08:07 PM
ReAX's Avatar
For where to get one, try locally, keep you dollar near home. Plus the boxes are quite big and expensive to ship.
__________________
-MECP 06/27/08
  #4 (permalink)
Old 05-05-2008, 09:26 AM
RealTruckMan's Avatar
FTE Sponsor
RealTruckMan is gaining momentum as a positive member of FTE.
Quote:
I have many to choose from, and also offer a free shipping on most of them.
__________________
Thanks,
Dustin Keyes
dkeyes@realtruck.com
RealTruck.Com Automotive Accessories
Call 7 Days A Week 1-877-216-5446 Ext 105
www.realtruck.com
Get 5% off almost any order when you enter or mention coupon code: dk123
  #5 (permalink)
Old 05-05-2008, 12:29 PM
knife141 is starting off with a positive reputation.
I have had an Access Roll-Up tonneau cover on my 2004 Ranger for 4 years. The truck is always parked outdoors, and the tonneau cover is still like new. It was easy to install, and is easy to roll up & down. The velcro on the sides has held up very well, as has the entire cover. I bought it online (don't rmember where, but there are a number of online dealers who sell them). Since this is the only tonneau cover I've ever had, I can't comment on how it stacks up against other brands.
  #6 (permalink)
Old 05-06-2008, 09:55 AM
Truck Stuff's Avatar
FTE Sponsor
Truck Stuff is starting off with a positive reputation.
Do some research, look at other peoples and see what will work best for you. I have been selling alot of Tri-Folds, people really seem to like them. I also think they are the best. Shop around a little bit and if you have questions I or anyone here will be happy to help you out.
__________________
Anthony P
Customer Service Agent
www.BuyAutoTruckAccessories.com
866-205-5299- Call with questions whenever
Free Shipping On Orders Over $100 Dollars*.
Same Day Shipping.
FTE Promo Code: FTE15200
Use this promo code and save $15 when you spend $200, (good till 6/30/08)
FTE Sponsor
  #7 (permalink)
Old 05-07-2008, 09:39 AM
beartracks's Avatar
beartracks is starting off with a positive reputation.
I like the extang vinyl with snaps although my last one was a little loose.
__________________
Bear Tracks
1977 F-100 Ranger XLT,400,C6,GV
Mod's Listed in Gallery
Click Here To Help Support FTE
  #8 (permalink)
Old 05-07-2008, 11:12 AM
bgalaxy67's Avatar
bgalaxy67 is starting off with a positive reputation.
I have a Top Deck on mine. It has shocks to help lift not the piano hinge. I like it. I put the Auto lock tonneau actuators on it
__________________
If the listening level is too loud, promptly inform the driver, so he may pull over, and let you out
My Excursion
Wife's 250
  #9 (permalink)
Old 05-08-2008, 02:52 AM
ReAX's Avatar
Most all hard tops come with shocks, but it's the non-removeable hinges that I hate. They require you undo the frame to pull the cover. Undercover's hinge has two key-ring type split rings that hold the cover on the rear brackets, so you pop those and the shocks loose and the cover slides off. It makes life easier, esp on the install.
__________________
-MECP 06/27/08
  #10 (permalink)
Old 07-02-2008, 10:46 AM
ambman142 is starting off with a positive reputation.
I have had 2 soft vinyl snap covers installed on my truck and they both worked fine at keeping out water. Although there is a little water in the bed from time to time, I believe that it could come from around the toolbox. The reason for the 2 seperate covers are that I lost the tailgate rail of my SportMaster/ TonneauMaster cover and apparently they have went out of business, as they have not returned phone calls or emails in over 2 months. I just replaced my cover with a Berlin hinged cover, that snaps and also opens on a hinge about 8-10 inches back from my toolbox. This cover appears to be of an even higher quality than the SportMasters cover that I was perfectly fine with until I lost the tailgate rail. The added convenience of the hinged opening is fantastic though and the total cost of the custom sized cover was $250.00 including shipping was more than worth the money. The product arrived at my home in 2 days (UPS). The cover installed in approx 20 minutes with only a 3/8" & 7/16" sockets. The only improvement I could suggest is clearer installation instructions. I had no problem with the installation, as I had already previously installed a similar cover, but a novice might get a tad confused. I don't work for the company, but thought everyone should know about a product that seems to work great and won't break your budget. I bought the cover through Ebay and the seller was very helpful, knowledgeable, and made sure we had all the correct measurements before completing the order.
  #11 (permalink)
Old 07-02-2008, 06:12 PM
bcrab is starting off with a positive reputation.
I have the Truxedo low pro and it works great.
__________________
2005 FX4 SCab
AFE CAI
Edge Evo
2" AutoSpring
Tinted Windows
Magnaflow SIDO
Bushwacker Pocket Style Flares
Truxedo LowPro QT
  #12 (permalink)
Old 07-21-2008, 12:14 AM
Fattybodaddy is starting off with a positive reputation.
I've used Access covers for about 10 years and love them. The original one I bought is still on my 92 chevy I sold to my dad and still is holding up great.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
