Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford Inline Six, 200, 250, 4.9L / 300
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-04-2008, 02:11 PM
ghreds's Avatar
ghreds is starting off with a positive reputation.
Question Rubber valve cover gasket-sealer or no?
Who uses gasket sealer on their rubber vc gasket? Who gets a good seal withouth it?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-04-2008, 02:36 PM
fmc400's Avatar
fmc400 has a good reputation on FTE.fmc400 has a good reputation on FTE.
double post
  #3 (permalink)
Old 05-04-2008, 02:37 PM
fmc400's Avatar
You'll want to use some RTV on the gasket-to-valve cover surface to get it to stick to the valve cover while you place it on the engine. You should be able to get away without using any on the cylinder head-to-gasket surface. The important thing is that the cylinder head surface and the valve cover flange are nice and clean, and that the valve cover flange is flat. It's also important to torque the valve cover bolts down evenly and in the proper sequence, to avoid warping the flange. The RTV is more as a place-holder than a sealer in this case. Don't use too much, either. A light bead all around will get the job done.
  #4 (permalink)
Old 05-04-2008, 03:28 PM
ghreds's Avatar
Thanks fmc400. What do you mean by double post?
  #5 (permalink)
Old 05-04-2008, 05:15 PM
fmc400's Avatar
What happened was I posted a response to your question, and my browser got stuck after I hit "reply." So I hit reply a second time to move forward. When I got back to the page, my post was there twice. To eliminate confusion I just cleared out one of the posts since they were the same. Just an internet error. Usually when a moderator sees "double post" like that, they know that it's safe to remove and they'll take it off just to keep things nice and tidy.
  #6 (permalink)
Old 05-04-2008, 11:41 PM
Corner Gas's Avatar
Corner Gas is starting off with a positive reputation.
I prefer the cork vc gaskets, they seem to seal better than the rubber from my experiences with them.
__________________
Colin
2000 PSD F250XLT Ext cab, SB, 4X2, Zoodad, ccv, Kwik filter W/Pete's cover , 4" turbo back flo-pro ss exhaust, fog lights & box cover
1967 Mercury F500 330, 2 spd axle 8 x 12 box & hoist
1978 F100 Custom 300 I6 (fresh), 4spd std (rebuilt) new hubcaps.
Life is to short to drive an ugly truck
  #7 (permalink)
Old 05-05-2008, 12:54 PM
ghreds's Avatar
Ya I was just thinking that since I was going to be pulling the valve cover off several times over the next few weeks working on the rocker arms / studs, that I could use reuse the rubber gasket. I finally got it sealed good, and I think at least one of the rockers is too tight. Sounds like a vacuum leak. popping out of the carb.
Thanks
  #8 (permalink)
Old 05-08-2008, 05:26 PM
woodbutcher05 is starting off with a positive reputation.
A neat little mod that a friend of mine did was to use studs and NyLoc(R) nuts to mount the valve cover.He switched to the FelPro(R) "rubber" gasket.Works great,AND,the studs help hold the gasket in its proper place when installing.
Leo
  #9 (permalink)
Old 05-09-2008, 06:00 AM
meck1 is starting off with a positive reputation.
I recommend trashiing the rubber gasket and using a cork. Rubber is easier to get on but a constant source of leaks. Not worth the hassle.
  #10 (permalink)
Old 05-10-2008, 12:16 AM
ghreds's Avatar
Well y'all talked me into the cork. The rubber is leaking like....I dunno, something that leaks really bad. One more question, though. I use rtv on both sides of the gasket. Is that normal practice?
Thanks,
Greg
  #11 (permalink)
Old 05-10-2008, 01:44 AM
Ford_Six's Avatar
Ford_Six is a splendid one to beholdFord_Six is a splendid one to beholdFord_Six is a splendid one to beholdFord_Six is a splendid one to beholdFord_Six is a splendid one to beholdFord_Six is a splendid one to beholdFord_Six is a splendid one to beholdFord_Six is a splendid one to behold
The rubber gasket goes in dry, aside from maybe using some adhesive to hold it to the valve cover IF the retaining tabs are damaged, otherwise bone dry. Same for the cork, although I usually use hi-tack to hold it to the valve cover since most cork gaskets don't have retaining tabs.
The key on these engines is to not over-tighten the valve cover. Between the long span between bolts, and the light gauge of the valve cover steel, it's hard not to have problems. Rubber gaskets have the worst problem, since they need fairly even force and don't crush as much as cork.
You'd be best using a tapered punch to pop the bolt holes up on the valve cover, then very carefully tighten to just past snug, and go around the valve cover a couple times. If you over tighten, it's cooked. Tighter will make more leaks.
__________________
Jared
Quote:
Originally Posted by Tadao Ando
"If you give people nothingness, they can ponder what can be achieved from that nothingness."
FTE Guidelines
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
