Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > 335 Series- 5.8/351M, 6.6/400, 351 Cleveland
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-04-2008, 12:54 PM
Tre-E_Ford's Avatar
Tre-E_Ford is gaining momentum as a positive member of FTE.Tre-E_Ford is gaining momentum as a positive member of FTE.
Remanufactured Engines
So, i have a 1977 F250 4x4 with the 400. Its a tired out old engine, but i love it. I understand the potential of a 460, but i like the uniqueness of a 400. Plus the temptation to build up the 460 is too great, and i just want a reliable motor.
So my question is, what do you think about remanufactured engines? Which companies are the best? Empire Engine Sales?
Any input is much appreciated?
__________________
Alex
STG's Minions: Desert Specialist
77.5 F250 A.K.A. Maggie - waiting for tube
http://www.ford-trucks.com/user_gallery/displayalbum.php?&userid=451025&albumid=33177
70 Bronco - Race Truck...eventually
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-04-2008, 02:14 PM
johnboy427's Avatar
johnboy427 is starting off with a positive reputation.
I have never been a fan of reman engine most seem to be very low quality. The ones we used to sell were junk and nothing more we got a 351C 2v in for a guy and it had one 351C head and one 400 head this made one bank run almost a full point higher compression on one bank, needless to say it never ran right and only lasted about 20,000miles. I have only seen one reman that was decent and it was a Jasper. The 400 suffered many short comings from the factory that really don't allow it to live up to its potential, it is really easy to make huge power and pretty decent milage gains if rebuilt correctly. If you do nothing esle I would run zero deck pistons from TMI these motors had very low compression from the factory, if you really want to wake it up go zero deck with aussi heads, you can get away with above 9:1 compression big change from 7.5:1 or 8:1 most of these motors had stock. I'm sure others here can provide more info.
-Johnboy
__________________
-1979 F-250 4X4 400 4spd
-1989 Bronco 300six swapped in ZF 5spd
-1967 Mercury Comet Sports Coupe
  #3 (permalink)
Old 05-04-2008, 03:11 PM
UTfball68's Avatar
UTfball68 is gaining momentum as a positive member of FTE.
I'd stay away from a remanned engine and put that same money into a rebuild for your 400...or just search and find a good running 460 with the potential to be built up.
__________________
___'77 250 400 37 Boggers____'96 350 CC 460 35 SSR's_____'79 Bronco 351M 35 M/T's
Ben
  #4 (permalink)
Old 05-05-2008, 07:36 PM
trinogt is starting off with a positive reputation.
Take your block and parts to the machine shop and assemble the long block yourself if you want to save money, or just get a quote from some reputable shops (try to find Ford shops; look for Ford signs on the wall! ), buy your TMI parts, Aussie heads if you please, and drop everything off. Shouldn't cost a whole lot, and will last you a very long time.
__________________
Mark in FL
restoretherepublic.com
  #5 (permalink)
Old 05-05-2008, 07:58 PM
60F100 is starting off with a positive reputation.
Do a search for the M block on the web. There is a wb site out there ( I don,t remeber what site it is) that has a lot of good info on what can be done to the M block. If you decide to switch to a big block you should be abel to use the same tranny. Same bolt pattern
  #6 (permalink)
Old 05-05-2008, 10:56 PM
TMI TMI is offline
TMI is starting off with a positive reputation.
We sell a crate motor for about $3600.
Not as cheap as some of those Ebay motors,
but plenty of quality parts and machine work.
If your interested, drop me an email and I will send you a detailed
list of machining and parts.
__________________
Tim
  #7 (permalink)
Old 05-07-2008, 03:55 AM
brthevio's Avatar
brthevio is starting off with a positive reputation.
I really can't complain about remans. I bought one from a guy on ebay and I haven't had any problems. But, it is a reman from ford. He bought it for a bronco that he had and somebody bought the bronco for more than what he had invested in it without the motor. Needless to say he didn't have any use for the motor anymore so I got it CHEAP!! I don't know what the actual ford remans go for but I am sure that they are more than what I paid. I got lucky, keep your eyes open and you might too!! The other guys are right though. If you buy the parts yourself and have a reputable shop do the work atleast you know exactly what you have. Not to mention you can do some upgrades alot cheaper that way. Better pistons, cam, high quality rings and bearings. Things that if you bought a reman and decided to do would cost alot more being that the motor would have to be torn down. I guess in my opinion if you don't need to motor ASAP, like I did, the better option would be the rebuild.
__________________
81 F-150 Ranger
351M
C6
9" rear
86 Interior
THE HEARTBEAT STOPS HERE!!!!!
  #8 (permalink)
Old 05-08-2008, 09:20 AM
Tre-E_Ford's Avatar
Thanks for all the help guys, i'll think about it more, i'm leaning towards a rebuild now, i want to assemble it myself(not my expertise, so i want to learn) w/ the help of a friend(very good w/ motors). thanks again.
__________________
Alex
  #9 (permalink)
Old 05-08-2008, 09:51 AM
Beechkid is new and has a neutral reputation at this point.
Try gofastparts.com- They are in Redlands ca, sell just about every kind of crate engine known to man and typically cheaper than anyone else I have compared during the past 15+ years! Customer service is excellent!!!!
__________________
"Beechkid"
Member: Flatheads ain't so bad
Chevy owners have to cheat to win!
  #10 (permalink)
Old 05-08-2008, 10:41 AM
hollenjoe is starting off with a positive reputation.
Quote:
Good idea, but 400 engines hace thier tip and tricks, not all engince builders will have the knoledge to make power out of this engine, so you can always use this forum for this tricks, also use high compression pistons and other aftermarket parts, for these parts contact tim and here its his store :
TMeyer, Inc. Precision Automotive Machining
__________________
"All right baby, see what I´ve got right here in my hands, I´ve got it right in my hands to score you baby, I think im gonna yank on a one town! Look Out!" Uncle Ted
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
