05-04-2008, 07:57 PM
taking the injectors out isn't the hardest thing to do, all you do is push in the schrader valve (passengers side) to relieve the fuel rail pressure and take the three bolts off the fuel rail itself, one on the drivers, and passengers side and behind the intake manifold. and gently wiggle it off the injectors, if you want to pull the fuel rail too then go down to the local auto store and grab a set of plastic fuel line removers, the behind the intake manifold use a mirror to see the supply and return lines (they are with different sizes) and take the safety clip off both and compress the spring and pull the lines with the plastic fuel line removers. also the 3rd bolt is back there and a little hard to find and you will need to pull a little vacuum line.
Oh and you need to pull the injector's wiring clip, there is 10, 1 for each injector.
when reinstalling make sure you do not pinch an injector O ring it will cause a lean condition and a lot of problems
__________________
03 F350 v10
Kb supercharger
Autometer gauges
35" Baja Mtzs
