Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Modular V8 (4.6L, 5.4L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-03-2008, 11:35 PM
earlschieb is starting off with a positive reputation.
Question 97 F250, Light Duty, 5.4 problem
I have a 97 F250, Light Duty, with a 5.4, recently while driving it, no load, such as trying to run 30 mph through town, or just cruising along at 55 mph, it has a miss fire, surge, chug, or bucking, but under no load sitiuations only, runs fine under a load, or at idle, or coasting. You can let off of the throttle, or push the throttle down a little and make the truck work, and the above symptoms are gone. No check engine light. Help Please!
  #2 (permalink)
Old 05-04-2008, 08:03 AM
projectSHO89 is gaining momentum as a positive member of FTE.projectSHO89 is gaining momentum as a positive member of FTE.
Standard misfire problem under load. Bad COP.
Advanced SEARCH keyword "misfire" and look for posts by either myself or jbrew.
Steve
__________________
Think about it: Ignorance can be addressed through education but you can't fix stupid! ...apologies to Ron White
  #3 (permalink)
Old 05-06-2008, 08:39 PM
Thanks for the information, I did go ahead a do the Advanced Search, and read all about it, interesting reading.
Tonight, I drove it to the next town over, it did the usual stutter, misfire, crap, and then it misfired at a stop, at a traffic light, and 3 minutes later the check engine light came on, I have a hand held code scanner, so I checked the code, hoping for a P030x code, to tell me which cop it was, nope, I got a P0401 code (Exhaust Gas Recirculation Flow Insufficient Detected) what ever that means? Egr valve stuck open?
  #4 (permalink)
Old 05-10-2008, 07:29 AM
Nah, probably either clogged EGR ports or a bad DPFE sensor.
Again, that advanced SEARCH is going to be your best tool.
Steve
__________________
  #5 (permalink)
Old 05-10-2008, 08:19 AM
Thanks Steve, I did the advanced search, the other day, about the cop, my biggest problem is lack of a decent internet connection makes it real tough to do much searching at 14.4k.
  #6 (permalink)
Old 05-10-2008, 09:20 AM
Dang, that has to be painful... As much as I hate Wildblue, it's still better than 14.4K (most of the time).
Steve
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
