I have a 97 F250, Light Duty, with a 5.4, recently while driving it, no load, such as trying to run 30 mph through town, or just cruising along at 55 mph, it has a miss fire, surge, chug, or bucking, but under no load sitiuations only, runs fine under a load, or at idle, or coasting. You can let off of the throttle, or push the throttle down a little and make the truck work, and the above symptoms are gone. No check engine light. Help Please!
Thanks for the information, I did go ahead a do the Advanced Search, and read all about it, interesting reading.
Tonight, I drove it to the next town over, it did the usual stutter, misfire, crap, and then it misfired at a stop, at a traffic light, and 3 minutes later the check engine light came on, I have a hand held code scanner, so I checked the code, hoping for a P030x code, to tell me which cop it was, nope, I got a P0401 code (Exhaust Gas Recirculation Flow Insufficient Detected) what ever that means? Egr valve stuck open?
Thanks Steve, I did the advanced search, the other day, about the cop, my biggest problem is lack of a decent internet connection makes it real tough to do much searching at 14.4k.
