Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Electrical Systems/Wiring
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-03-2008, 10:26 PM
dw1_hoosier is starting off with a positive reputation.
Battery Backwards
I am replacing my battery in my 1990 F-150 and I'm wondering if the previous battery was installed backwards, because it is seems to be installed upside down. Does the positive or negative terminal need to be connected to the solenoid on the fender?
Sorry for the dumb question, I've been searching for an answer in this forum for 30 minutes. Thanks.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-03-2008, 11:05 PM
blakeusa is starting off with a positive reputation.
battery
Not sure of your question, but the positive battery cable connects to the battery side of the starter solonoid on your fender (front of car). The starter side (firewall side) of the solonoid should have a large cable that connects to the starter motor.
Batteries do come in different configurations i.e which side the positive and negitive terminals are located, as well as amperage, storage etc.
If i understand your question it is possible that your old battery was not the exact/correct model for your truck. Either that or your new one is wrong.
As long as your cables can reach it does not really matter, as long as you have the correct CCA, or cold cranking amps to drive your starter.
  #3 (permalink)
Old 05-04-2008, 10:08 AM
Franklin2's Avatar
Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.
Positive to the solenoid.
__________________
Dave F
1989 F250 XLT Diesel
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
