Can or should you tow in OD Overdrive?
Welcome to FTE.
That depends on what truck you have, what you're hauling (weight & wind resistance), the terrain you're driving through, and how hard you accelerate. It can be done, but if you're in a situation where the tranny has to repeatedly hunt for gears then you're better off staying in tow mode.
Mom, your profile says you have a 2009 F250. Now, I know So Cal is progressive, but I'm figuring you don't really have an '09.
But if you did, or if you have anything back to '03.5, you have a torqshift with tow/haul mode. On that transmission you cannot lock it out of OD. You can downshift, but only to 3rd or lower. You cannot lock it in 4th. Tow/haul does not lock out OD.
So your truck has answered that question for you. It won't let you do that. Leave it in OD. Use tow/haul if you like the shifts better. I usually only use it going downhill.
Bill
Bill
Welcome to FTE.
only tow in OD if you have a diesel, then use tow mode. Gas truck 5.4 or v10 best to not use OD. The truck and transmission will do better by keeping you at a better rpm.
I have always towed in OD when possible - meaning that when the terrain was realatively flat and the tranny would go in to OD with out 'hunting'. My previous truck was a 00 F150, 5.4, and I towed a 6700# TT; Current rig shown below. There is nothing wrong with towing in OD.
Mark Moore might be more right than I am. Just found my 99 V10 liked to rev a little more. Found it liked 2700+ rpms when towing heavy. Great to have the input from other experiences so we can all learn. Just seems a 5.4 might really struggle towing in OD. If the truck has tow mode shouldn't be a problem?
That's what I thought when I got the torqshift. The F150 4R75E could be locked out of OD, but the 5R110 in the F250 cannot. I guess they wanted to use the stalk button for the Tow/Haul mode, and would have had to have a separate button for locking out OD, or else add a 4th gear position to the shifter. It really does not need that function however.
But it won't struggle in OD. It will shift down on it's own if needed. And the torqshift strategy is smart enough to limit gear hunting on it's own. It's the first automatic transmission that I've ever owned that really seems as smart as the driver. I almost always knows what to do. Almost. It still cannot see ahead and anticipate the crest of a hill like I can.
Bill
Bill
It's 100% fine to tow in OD with an auto or a manual. Why not on a manual? You're not going to burn up a clutch (unless you're downshifting really really hard?). I'm guessing it's because most idiots out there would run 5th gear right into the ground until the engine bogs down and complain of zero power and some weird engine problems. The TorqShift is a solid platform that, like BPounds said, is smarter than most drivers. Mine was kind of weird with light loads (<3000 lbs) in the mountains in Colorado, but other than that it's great.
