Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Y-Block V8 (239, 272, 292, 312, 317, 341, 368)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-03-2008, 08:11 PM
OldSchoolRodz is starting off with a positive reputation.
Question Distributor Question?
Can anybody tell me what a vintage "Mallory Reverse Polarity Dual Point Distributor" is? Is it in some way different than a stock configuration Dist?
I believe old Marine Y Blocks had a reverse firing order? Would this be for that application?
Could it be used on the vintage Y Block I'm rodding for my 55 F100?
Thx, David
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-09-2008, 12:20 PM
312 312 is offline
312 is starting off with a positive reputation.
reverse polarity just means positive goes to ground.the system in your 55 is 6 volt positive ground.i cant tell you any more than that.
  #3 (permalink)
Old 05-09-2008, 09:43 PM
Thx for the stab at it! David
  #4 (permalink)
Old 05-28-2008, 09:34 AM
85lebaront2 is starting off with a positive reputation.
The old Mallory "Rev-Pol" distributors used two sets of points on a 4 lobe cam for V8s. They used a special coil with 1 positive and 2 point terminals if my memory is correct. One set of points was connected to each terminal. Reverse polarity actually referred to the spark output, much like the DIS systems with 2 plug coils, half are positive output, half are negative output. If you want to use it with anything other than the original Mallory coil, be sure both point sets are connected, and only use 1 condenser. For best results you need a distributor machine to synchronise the points.
__________________
Bill Vose (Old School Hot Rodder)
1985 LeBaron convertible 2.2L TurboII
1986 F350 crew cab DRW 460ci
1986 LeBaron convertible 2.2L TBI (dead)
1986 Turismo 2.2 (race car)
1989 LeBaron J body convertible
1989 LeBaron J body coupe
1993 Grand Caravan 3.3L
1995 Lincoln Continental (project car)
http://www.oldschoolhotrodder.com
  #5 (permalink)
Old 05-28-2008, 11:27 AM
Thx Bill,
Thats the best education a fellow could expect. I let that Dizzy pass cause I couldn't identify application considerations. I'm still keeping my eye out for the right vintage Distributor for the Y-Block I'm rodding Old sKool.
Keep it Kool, Keep it Old Skool. David
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
