Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Cooling, Heating, Ventilation and A/C
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-03-2008, 05:56 PM
bcjim is starting off with a positive reputation.
03 Explorer, No AC, short cycle
The gauge on the refill can of r134 says pressure is good but no AC. Compressor is short cycling and it is blowing no cold air. Any easy things to check before I go to dealer.
I had a blend door repair done over the winter, they tore apart the dash and console, I dont know what else was involved it was a warranty job. Warranty is now expired. Any chance they may have forgot to reconnect something or otherwise goofed up the system?
__________________
98 Ranger SC 4X4
03 Explorer 4x4
  #2 (permalink)
Old 05-03-2008, 10:39 PM
projectSHO89 is gaining momentum as a positive member of FTE.projectSHO89 is gaining momentum as a positive member of FTE.
Gauges on the cans are usually useless unless you know how to read them (the compressor HAS to be engaged in order for the color bands to be relevant.
Short-cycling is almost always due to a low charge. Low charges are due to leaks. A leak means it must be found and repaired. That means the system then has to be evacuated properly and recharged.
It won't be cheap.
Steve
__________________
Think about it: Ignorance can be addressed through education but you can't fix stupid! ...apologies to Ron White
  #3 (permalink)
Old 05-06-2008, 08:12 AM
hhott71 is starting off with a positive reputation.
low charge 95+% of the time
bad cycling switch less than 5% of the time
thats the 2 biggest reasons.
when hearing hoof beats, think horses, not zebras.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
