Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > 335 Series- 5.8/351M, 6.6/400, 351 Cleveland
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-03-2008, 11:42 AM
DJOHNSTON78 is starting off with a positive reputation.
Sp2p Intake which cam to use?
I've just won a Sp2p Edelbrock intake and would like to know if a Dual energy 255 style cam would work great with a stock 400
  #2 (permalink)
Old 05-03-2008, 12:52 PM
UTfball68's Avatar
UTfball68 is gaining momentum as a positive member of FTE.
Sure will...a lot of guys around here will recommend that cam for a basically stock 400, along with an XE256.
__________________
___'77 250 400 37 Boggers____'96 350 CC 460 35 SSR's_____'79 Bronco 351M 35 M/T's
Ben
  #3 (permalink)
Old 05-10-2008, 09:45 AM
Do you have to worry about guide plates with this cam?
  #4 (permalink)
Old 05-10-2008, 11:04 AM
hollenjoe is starting off with a positive reputation.
not guide plates, but springs, although I suggest changing your springs to ones that match your cam, stock springs will maybe hold.... and if your engine has exhaust rotators you should change them to guide plates...
__________________
"All right baby, see what I´ve got right here in my hands, I´ve got it right in my hands to score you baby, I think im gonna yank on a one town! Look Out!" Uncle Ted
  #5 (permalink)
Old 05-10-2008, 07:49 PM
80broncoman is starting off with a positive reputation.
I hope that cam is small enough not to have a lope. Those intakes were designed for stock engines. Do NOT raise compression with a SP2P intake above stock, The dynamic compression can get very high. It the only thing thats worse than useing a large cam with it.
__________________
Real men don't wear Bowties
  #6 (permalink)
Old 05-11-2008, 12:10 PM
the intake has nothing to do with your dcr, that itake works grate with rv cams, the down side to it its that it aint worth for alot of rpm....
__________________
  #7 (permalink)
Old 05-11-2008, 04:40 PM
Quote:
You don't think the intake can have a tuning effect of cylinder pressure?
Intake manifolds have almost as much influnce as camshafts do over what RPM the engine will work best in.
__________________
  #8 (permalink)
Old 05-11-2008, 04:54 PM
Not realy in cylinder preasure, but it will affect in port velocity, cyllinder preasure is only afected by the event of openning and closing valves, the charge or mixture will be afected by port velocity thus afecting power at low rpm, this itake has small intake runners which will increase port velocity, thus will increase low end torque and throttle response... I know for a fact that it has nothing to do with dcr....
S - small, P - port, 2 - dual, P - plane. Small port dual plane manifold for low and mid range
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
