id my pumpkin for me
Old 05-03-2008, 09:31 AM
400944's Avatar
400944
400944 is offline
Question id my pumpkin for me
here it is this is off a 1969 ford f 100
i just pulled both axles and they are 28 splines each
the inside of the pumpkin is marked C7AW - G24
underneath the pumpkin on the outside is a raised number 39
on the ring gear it is stamped USA C3AW 4210 8 (TRIANGLE) -1910
the differential that transfers the power is marked D C6AW 4206 DIF 19
on each of the main caps that secure this assy is marked 4224
i recently spun my my ring and pinion and need to replace this assy
complete if possible with a suitable replacement that will work with this info i provided
i need an explanation of these numbers and what am i looking at
Old 05-03-2008, 02:27 PM
85e150's Avatar
85e150
85e150 is offline
Received 1,595 Likes on 1,300 Posts
You are looking for a 28 spline 9 inch, locker, limited slip, or open, your choice.
Expect to pay $50 for one that needs a complete rebuild, and $400+ to $1200 for rebuilds that meet or greatly exceed stock specs.
If you didn't break your case, yours can be rebuilt as well, again, you can add the locker or limited slip.
BLADE35
03-19-2017 08:37 PM
jcthorne
03-02-2017 10:03 PM
Nicholas+
13
09-30-2015 11:23 PM
Super Wagon
13
08-03-2011 06:44 PM
79_250RangerLariat
03-23-2009 11:00 PM
Quick Reply: id my pumpkin for me
